Author: Subject: Velocity mirror position
Steve Lovelock
posted on 19/4/08 at 12:36 PM Reply With Quote
I have a pair of GSXR type wing mirrors that I need to fix to my Velocity. However, I am not planning on fitting the screen for SVA so I need to know where to put the mirrors. I do not want the holes I make now to visable when I have fitted the screen. So I would dearly like the height from the base of the scuttle and the distance back from the front edge of the centre point of the mirror's base so that I can position it correctly.
Hope that makes sense.
adz h
posted on 19/4/08 at 05:38 PM Reply With Quote
Hi I installed the windscreen then removed it for SVA as the holes are different no both sides if you are using the luego windscreen brackets coz you have to bend them
piddy
posted on 19/4/08 at 07:38 PM Reply With Quote
Hi. I wanted to do the same as you but found that if you fit the mirrors onto the screen mounting brackets you can't see enough out of them,so i ended up putting in front of the screen bracket.
