Author: Subject: SVA look-over please
FASTdan
posted on 15/3/09 at 04:15 PM Reply With Quote
The usual if you could please
Replacement passenger mirror is ready to go on. We havent covered the track rods + camber adjuster yet as we need to set up the self centering.
It does need a good clean and hoover out but as far as we can tell we think were almost there.
[Edited on 15/3/09 by FASTdan]
[Edited on 15/3/09 by FASTdan] Rescued attachment PB160001.JPG
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
Howlor
posted on 15/3/09 at 04:19 PM Reply With Quote
Looks good, you may need a cover over the front shocks adjuster. I just pushed a but cover over.
Also is the edge of your aero screen to the correct radius? You may be better taking it off for the SVA.
[Edited on 15/3/09 by Howlor]
FASTdan
posted on 15/3/09 at 04:20 PM Reply With Quote
Yeah its actually got them on - you cant really tell in that pic.....
hold on guys im uploading more pics but its taking its time......
Howlor
posted on 15/3/09 at 04:21 PM Reply With Quote
I meant the adjuster knob.
stevec
posted on 15/3/09 at 04:22 PM Reply With Quote
The mirror mounting points may be a bit sharp, can't see them very well, and if it was me I would loose the aero screen until after the test.
Looks a very nice build indeed.
Steve.
neilj37
posted on 15/3/09 at 04:32 PM Reply With Quote
I cannot quite make out the bonnet catches that you are using. Are they SVA compliant as the edges look quite sharp in the photos.
Do you need to fit something on the centre of the steering wheel?
marshall
with the cable tie's push the square bit
were it has been cut push it under out of the way.so the tie is just showing.as
they fail you on this as a sharp edge..
omega 24 v6
posted on 15/3/09 at 04:34 PM Reply With Quote
Batt +ve needs a cover as do starter and alternator +ve terminal. Bleed nipples to cover edge of flat bar on front wing stay (horizontal brace between round bars).
Bonnet securing ( don't know how your doing it but there are bits sticking out at the moment.
ETA
tranny cover and cockpit edges look like they'll need a bit of attention as well they look quite sharp in the pics.
[Edited on 15/3/09 by omega 24 v6]
posted on 15/3/09 at 04:43 PM Reply With Quote
Rear reflectors?
tomgregory2000
posted on 15/3/09 at 04:44 PM Reply With Quote
i would take off the number plate holder till after the test
McLannahan
posted on 15/3/09 at 04:47 PM Reply With Quote
Originally posted by BenB
Rear reflectors?
On the rear arches below the lights. Difficult to see though against the colour!
FASTdan
posted on 15/3/09 at 04:52 PM Reply With Quote
Thanks for the replys - all good stuff.
I forgot to mention the nasty sierra wheel will be on for the test.
I'll check cockpit edges out.
Aero screen was indeed too sharp! We've just started rounding it off - I notice a couple of you saying take it off, is there any other reason other than the rad?
Rear reflectors are on - under the lights you just cant see them very easy against the red, unless you mean something else about them?
Mirrors are from CBS and state 'SVA ok' so I assume they are ok - they seem to be radiused on all edges.
Good point on the square tie bar! And the positive terminals - wasnt aware of that one.
Will remove numberplate holder if its going to be an issue?
Does the rear fog angle look ok - I've read some stuff about being vertical etc?
Bonnet catches are the rubber ones from RS components - I think a few people on here have used them and passed SVA with them?
You may also notice the drivers side track rod end is the wrong side! Going to get the right one on there this week (previous owner fitted opposite way around!).
prawnabie
posted on 15/3/09 at 04:58 PM Reply With Quote
Not really SVA, but I reckon the front wing supports need beefing up, only 1 support will not last long at all - id be suprised if they were still both attached when you got to the SVA lol
Shaun
MK chippy
posted on 15/3/09 at 05:13 PM Reply With Quote
Shaun
They look the same as mine and they were supplied by MK. They are fixed at the top and bottom of the front hubs.
FASTdan
posted on 15/3/09 at 05:20 PM Reply With Quote
Shaun
Yeah thats right
prawnabie
posted on 15/3/09 at 05:50 PM Reply With Quote
Ahh my bad...
mistergrumpy
posted on 15/3/09 at 06:05 PM Reply With Quote
Rear reflectors are not radiused around th edges. The harness mounts need trim around them and it doesn't look like the mushroom adapter in the front hub has been bolted through. This one's on the increase, you need to drill right through the hub and one side of the mushroom and bolt it or tap it so the mushroom can't pull out.
Oh and another one that's getting pulled on some but not all is the unradiused edge on the steering arm of the front hubs.
[Edited on 15/3/09 by mistergrumpy]
bill132hotrod
posted on 15/3/09 at 06:06 PM Reply With Quote
SVA CHECK
Hi there you need to drill and bolt your front suspension mushrooms. Easy to drill from rear and tap a tread in then fit small bolt.
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
RichardK
posted on 15/3/09 at 06:23 PM Reply With Quote
^^^^^ What he said above about drilling and bolting the mushrooms inserts, I was at Beverley and he picked up on this with me and I have to prove that my set screw actually entered the insert as I threaded the upright. Thankfully I had pictures to prove it did!!
Rich
[Edited on 15/3/09 by RichardK]
Gallery updated 11/01/2011
tomgregory2000
posted on 15/3/09 at 06:26 PM Reply With Quote
^^^^^^ I didn't do mine and no comment was made at my sva
RichardK
posted on 15/3/09 at 06:29 PM Reply With Quote
I mentioned it as his location is Bradford and probably is going to Beverley. Where I went, I believe the mushroom thing is a regional thing with sva, different interpretations of the rules.
Rich
Gav
posted on 15/3/09 at 07:16 PM Reply With Quote
You need to trim the edges all round the seats not just the harness holes or it will fail the radius check.
Marcus
posted on 15/3/09 at 07:44 PM Reply With Quote
I just noticed the brake flexis are touching the wishbones. You need to make sure there's no contact at all throughout the steering range. SVA don't like chafing..
Marcus
Because kits are for girls!!
Slater
posted on 15/3/09 at 08:32 PM Reply With Quote
To get the rear fog light vertical, undo the mounting screws a bit and wedge in some foam strip or small dia tubing between the top of the light and the housing.
FASTdan
posted on 15/3/09 at 08:48 PM Reply With Quote
Wow certainly some stuff we'd never considered coming out here, thanks again.
I had no idea about drilling through to prevent the mushroom pulling out. Not a problem though we'll get that done. Will also address the flexi's if they are rubbing anywhere.
We're booked into Chadderton on 31st March, so still a couple of weeks to iron out any issues.
