Author: Subject: Think ive actually found a 4pot heavier than a pinto!
StrikerChris
posted on 4/4/14 at 02:50 PM Reply With Quote
Picked up a rover t16 engine for my maestro yesterday.it got loaded onto the bedford rascal with an engine crane, after a journey home bouncing around on the bumpstops had to man handle it off at my end. Bugger me! Theres now 3 of us waiting for hernia ops with bad backs too! 2 of us can quite easily lift my sr20det onto the rascal.
Just how heavy are they?!
Chris
iank
posted on 4/4/14 at 03:51 PM Reply With Quote
IIRC they share a block with a diesel, thus the "sturdiness".
Anonymous
posted on 4/4/14 at 05:22 PM Reply With Quote
It is an MGB 5 bearing engine with a dohc head ,the origins go back to the 1947 Austin A40 Devon 1.2litre 40bhp engine which evolved into the 1500 BMC B series, which gained weight with various upgrades, then evolved into the O series, M series and eventually T series.
[Edited on 4/4/14 by britishtrident]
StrikerChris
posted on 4/4/14 at 05:25 PM Reply With Quote
Sturdy aint the word, I reckon ill be in profit weighing it in! No wonder bl went bust!
NigeEss
posted on 4/4/14 at 09:11 PM Reply With Quote
You've obviously not come across a Vauxhall CIH as fitted to Mk1 Cavaliers then
bi22le
posted on 4/4/14 at 10:41 PM Reply With Quote
Now that is some knowledge!!
I hope you knew that off of the top of the head with out google. Knowing your previous posts and thier detail, I would not expect any less.
Please read my ring story:
coyoteboy
posted on 6/4/14 at 10:17 AM Reply With Quote
Can't find any reliable info online but most groups seem to suggest it is about 110kg? (Though one did guess 200). The 3SGTE is a cast iron 4 pot which weighs in around 175 with manifolds and turbo!
Sam_68
posted on 6/4/14 at 11:19 AM Reply With Quote
That would be quite light for a cast iron 4-pot.
I weighed my old Crossflow (one of the lightest iron block engines) at 109 kilos with flywheel, clutch, inlet manifold and twin Webers. A Zetec is about 115 kilos and the Pinto is about 135 kilos, from memory.
jacko
posted on 6/4/14 at 02:51 PM Reply With Quote
http://www.gomog.com/allmorgan/engineweights.html
just found this if it helps
Jacko
