Author: Subject: Emissions on a Registered Car
ayh20
posted on 9/10/03 at 10:12 PM Reply With Quote
Sorry if this is a really dumb question:
I currently don't have to worry about emissions regs at the moment in my X-Flow Striker as she's "R" (1977) registered .
But when i change my engine to a modern Zetec i assume nothing changes so i can buy an engine of any vintage and just throw away all the emission control stuff like Cat's ?
Can't I ?
Didn't know what I was doing when I started .... And I still don't ... !!
zetec
posted on 9/10/03 at 11:55 PM Reply With Quote
I suspect you could have problems at the MOT if the tester works out the engine is later than the original. I suspect the car will be tested according to the year of engine. You will get away with no cat/carbs on a pre early 95 zetec, but latter than that all engine had a cat fitted. You're other option is to fit what you like and hope the MOT tester ain't got a clue as to what level he should test the emissins to!
Mk-Ninja
posted on 10/10/03 at 07:36 AM Reply With Quote
An MOT will be conducted against the cars reg. The only bit I am not sure about is when you change the engine do you have to go for an SVA or do you just inform the DVLA. I am sure that other will know about this.
Gordon
I'm sure I've got one, just don't know where I've put it
