phelpsa
posted on 23/5/04 at 02:25 PM |
Steering rack mounts
What do you think of my steering rack mounts?
Adam
phelpsa
posted on 23/5/04 at 02:28 PM |
Sorry
RoadkillUK
posted on 23/5/04 at 04:42 PM |
Looks strong enough to me, I thought that there wasn't enough strength in the steering rack mounts so I did similar.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
phelpsa
posted on 23/5/04 at 05:31 PM |
I took the design from Luego (I think).
Adam
Mark Allanson
posted on 24/5/04 at 06:02 PM |
I did mine with one diagonal using the theory that if the right hand one was supported, the rack itself would support the left - until I sat in the
car and moved the steering, the left support was moving about 3mm either side due to the play in the clamp rubbers. i welded in a cross diagonal to
brace both sides
pk
posted on 25/5/04 at 12:37 PM |
Rack mounts
Guys,
i started with a similar design, looks like you are going to be using a MK2 escort rack? After building i had to reposition to get rid of the bump
steer! By the way i have a suitable quick rack for sale see the for sale pages. I found that by lowering the rack and moving it back / forward the
majority of the bump steer could be removed - good luck!
phelpsa
posted on 25/5/04 at 06:25 PM |
Are the book dimensions very bad for bump steer as thats what I have made them to apart from the brace.
Adam
posted on 25/5/04 at 06:34 PM |
my steering rack sits flat on the lower chassis rails. i dunno why the book says to make them so high, cos mine are parallel to the lower wishbones as
they are. maybe cortina hubs are different to sierra ones?
Markp
posted on 25/5/04 at 07:24 PM |
I did't weld the steering rack mounts up until the engine was in and the suspension set up, I then positioned the rack to the height required, I
agree with JoelP. My supports are virtually off the bottom rail.
Mark
Lars
posted on 25/5/04 at 09:00 PM |
am i right in assuming that the rack should sit level with the holes where it attaches to the uprights?
