Alez
posted on 21/6/04 at 01:39 PM |
toe-out adjustment, how?
Hi!
This weekend, when I had a look at the car before adjusting toe-out (my original intention), I realized that the camber in one of the wheels is not
good (can't remember the sign, but the wheel is slightly closer to the car where it touches the ground). Common sense tells me I should adjust
the top wishbone, but I turned the nut there and realized it's just a lock nut, so by loosening it you don't reduce the wishbone length
which was my intention but just unlock the nut and leave it loose!
Then I tried to shorten the other rod to reduce toe-out. Unlocked the nut, then screwed the rod into the wheel bit (excuse vocabulary, hope it's
understandable) with a pair of big pliers, then locked the nut again. Then I thought I may be missing something and maybe that's all wrong and
by doing that I unscrewed the rod from the car or something? Oh I'm afraid I may have done something bad!
Many thanks for any advice.
posted on 21/6/04 at 02:07 PM |
he he, its all a worry!
to do camber, you jack it up, remove the top swivel joint from the hub, undo the lock nut (thats what you undid before) and then screw the upper
swivel into the top wishbone, then just do everything in reverse to put it back together. This is assuming your car is using a transit track rod end
as the upper swivel, so similar.
as for the toe in or out, remove the steering arm from the hub (ideally without a hammer!), then indo the lock nut, screw the end bit in or out. But
you must make sure, if you screw it out, that there is still plenty left inside the thread. Maybe mark its original position with the locknut and
remove it altogether to see what is left to play with.
Hope that makes sense!
ps, if you are reducing toe out, and you are sure you have the right thread (ie not left handed!) then you shouldnt be in danger of it falling out.
Its only when increasing toe out that you must be careful.
Plus the usual disclaimer, im incompetant, hell i cant even spell that damn word. Dont kill yourself on my account!
[Edited on 21/6/04 by JoelP]
Alez
posted on 21/6/04 at 02:18 PM |
Thanks a lot man, much appreciated, it was more difficult than I thought indeed.. which is kind of strange, considering how quickly these are normally
adjusted in my "normal" car when I take it to the quick fit for adjustment. Anyway, I'll now try as described, thanks!
posted on 21/6/04 at 04:53 PM |
Kwik fit thickies.
They only adjust the toe on your euro box, it doesn't usually have camber adjustment. You want your wheels in at the top (negative camber) or
upright and usually toe out is only used to get through SVA. A couple of degrees of toe in makes the car feel a lot more predictable on the road.
blueshift
posted on 21/6/04 at 05:54 PM |
It's easier to adjust the alignment on many production cars because it's set by eccentric bolts where the mounting brackets are, ie they
just loosen them, turn them a bit, tighten them back up.
pbura
posted on 21/6/04 at 06:22 PM |
It seems like just about everybody does their own alignment, but how about going to a shop? They've got these spiffy racks and lasers, way
better than my bumpy garage floor and angle iron, IMO.
Anyone have any experience having someone else do it?
Pete
Alez
posted on 22/6/04 at 08:31 AM |
Hi!
? I think they adjust both toe and camber, I seem to remember both figures in written form for my Golf..
they just loosen them, turn them a bit, tighten them back up.
So maybe if I turn up with my "strange" car they will tell me to f off
It makes a lot of sense to me, here it is very very cheap to have it done, much cheaper that having uneven tyre wear due to wrong camber for instance.
The problem is I don't think they will go into dismantling half of the steering setup to align everything for you, as production cars are
different Still you can probably DIY and then have the angles measured by their lasers just in case?
Alex
[Edited on 22/6/04 by Alez]
posted on 22/6/04 at 08:40 AM |
its no different from turning up in a sierra to get the tracking lined up! id do the camber at home, with a block and a plump line to measure it. i
did mine by eye. then take it to a shop to be tracked. its a 5 minute job! if the odle bastards wont do it then at least you know they are useless.
then you'll just have to do it yourself!
pbura
posted on 22/6/04 at 11:00 AM |
If you get the right place, you'll probably make their day! There's an old family-owned alignment shop in town here that would probably
be tickled to do it; maybe there's a car-loving counterpart in Madrid?
Pete
Bob C
posted on 22/6/04 at 11:07 AM |
interesting system of incentives. In UK we usually have to give money ;^)
Bob C
pbura
posted on 22/6/04 at 11:46 AM |
Oh, sure, everyone wants money (more and more these days, it seems).
As long as they don't want twice as much, and leave wrench marks all over the wishbones in the bargain.
Pete
Terrapin_racing
posted on 22/6/04 at 01:56 PM |
It's a sad reflection of the times here in UK. Personal experience tends to suggest you are far better off doing a bit of reading up on the
subject and then doing your own alignment.
The term Kwik Fit Kids rings familiar! I have reservations letting them loose on my road car - no way on my pride & joys!
you can get a good castor/camber tool from:
Alez
posted on 24/6/04 at 12:39 PM |
Thanks very much for your encouragement and suggestions. Went to a quick fit where a bike enthusiast I know works, told him about it, he told me
Sierras don't have camber adjustment so I plan to do as JoelP advises, take the car to this guy for toe adjustment after I've done the
camber by eye myself. He will measure the camber obtained anyway so I can fine tune later if need be. Also told me you can adjust toe in/out without
dismantling anything, just as I did, since the end of the rod that goes to the car (non threaded one) has a ball end and thus can turn freely for
adjustment. Will be going for it next weekend!
Many thanks again.
posted on 24/6/04 at 03:22 PM |
Also told me you can adjust toe in/out without dismantling anything, just as I did, since the end of the rod that goes to the car (non threaded one)
has a ball end and thus can turn freely for adjustment.
i forgot that! its good cos it means you dont have to stick to whole turns of the rod-end. more accurate, provided you can measure it.
Alez
posted on 28/6/04 at 06:46 AM |
Guys,
Thanks to your contributions I've now adjusted both camber and toe-out by eye. I shall now take the car to the quick fit for measurements, also
take the car for a proper (read fast) test drive.
Adjusting toe-out was absolutely straightforward as discussed with JoelP. To adjust camber, I had to dismantle not only the top wishbone but also the
spring-damper since in my car this is needed in order to remove the top wishbone bolts. All looking good!
