Author: Subject: Pug wheel centres
carnut
posted on 3/3/03 at 07:30 PM Reply With Quote
Pug wheel centres
Are Peugeot wheels of the same stud pattern as Ford?
I know they both use 4 stud but not sure on PCD.
auzziejim
posted on 3/3/03 at 07:43 PM Reply With Quote
Pug wheels
Yep they do share the same stud pattern but the offet is different
RoadkillUK
Some of the Pug wheels are the same PCD but you'll find the Central Bore is a little bigger on the Pugs, I'm not sure if that will make a bid difference but I'm sure someone here will know for sure.
Take a look here for wheel info
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
carnut
posted on 3/3/03 at 08:09 PM Reply With Quote
Nice with the different offset, ill have an even wider track indy!
Rorty
posted on 4/3/03 at 12:37 AM Reply With Quote
If the centre bore of the Pug rim is larger than the spigot on the Ford upright, you'll need to have the back face of the Pug rim machined to take a press-in ring, which effectively steps the centre bore down to the correct diameter. That way, the studs won't be taking all the load.
Cheers, Rorty.
"Faster than a speeding Pullet".
PLEASE DON'T U2U ME IF YOU WANT A QUICK RESPONSE. TRY EMAILING ME INSTEAD!
johnston
posted on 4/3/03 at 09:05 PM Reply With Quote
havent we had this convo bout centre spigots and studs b4???
