Author: Subject: 19mm radiuses (ii?), where do they apply?
Mark Allanson
posted on 17/3/03 at 07:36 PM Reply With Quote
Got the week off work, really attacking the car to catch up, I put in the steering today, and just finished. I used 13mm ERW round tube to mount the upper column, but now remember that you have to have radii of more than 19mm - does this appy just to the dash or anything behind it? Rescued attachment DCP_0619sml.jpg
Viper
posted on 17/3/03 at 07:42 PM Reply With Quote
i believe the 19mm rad is along the bottom edge of the dash, so the whole width of the dash..
Mark Allanson
posted on 17/3/03 at 08:35 PM Reply With Quote
Does it apply behind the dash?
Viper
posted on 17/3/03 at 08:41 PM Reply With Quote
the way i read it is the bottom edge of the dash, if the half sphere comes into contact then it should be radiused.
chrisg
posted on 17/3/03 at 08:54 PM Reply With Quote
Thet don't check behind the dash and anything behind the steering wheel is exempt - don't worry you're fine!!
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
Mark Allanson
posted on 17/3/03 at 09:08 PM Reply With Quote
thanks both, what do you think of the mount?
Viper
posted on 17/3/03 at 09:11 PM Reply With Quote
Very neat,,,
chrisg
posted on 17/3/03 at 10:30 PM Reply With Quote
Looks good Mate, beats the chewing gum and piece of hairy string I used!
Chris
David Jenkins
posted on 18/3/03 at 08:36 AM Reply With Quote
One comment on the mount - looks very neat, but watch that you don't have the same problem that I had...
Sit in the car, grab the wheel with both hands, and try to move the wheel and column side to side. If there's a noticeable waggle, then you might consider a diagonal brace (mine's cross-braced to the scuttle wall and pedal box).
regards,
James
posted on 18/3/03 at 10:30 AM Reply With Quote
Mark, I'm a little concerned: I know you lost your barn but looking at this picture you appear to be building at sea? Is your chassis currently balanced on top of a small rowing boat? Do the waves/wash not make welding a little hard? And how did you get a surface flat enough to get your chassis straight?
Or, is it really the case that you've been lying to us all along and you're really building a Pinto powered boat?
Concerned,
James
Dave Ashurst
posted on 18/3/03 at 04:25 PM Reply With Quote
They checked thoroughly behind the dash at my SVA a year ago.... but then they were checking for min 2.5mm radii (as I recall) on internal projections into the footwell area. I had to put plastic covers over the nuts inside the scuttle for the windscreen support bolts.
19mm radius applied only to the bottom edge of the dash.
I doubt anyone could be sure how they would interpret the rules for the legs of your nice column support structure if they were exposed below the bottom of the dash.
suggest phone them perhaps?
regards
Dave
Mark Allanson
posted on 18/3/03 at 09:35 PM Reply With Quote
David,
I got the mount 3mm out on first tacks, I put me portapower on it and the 500kg spreader would not budge it, I had to cut out and re weld - I woul be happy lifting the whole car on the mounts
James,
It's ok unless the swell gets above 6 foot, look at my avatar, i am only 1/2 mile away from the mount!
Dave,
the support is made of 13mm round EWR tube so should be ok on the 2.5mm rule, but I will look out for the rest of the stuff I bung under the scuttle
Thanks everyone
Mark
