Author: Subject: Escort based MK Set up
Bob da builder
posted on 5/4/04 at 02:00 PM Reply With Quote
Hey up kids,
well i guess that this has been discussed a million times before...
im running a MK escort chassis with gaz coil over shockers. any sugesstions on the suspension set up, camber, tracking, corner weights etc.. and a way of setting them up with out expensive guages etc...?
thanks a lot..
bob da builder
posted on 5/4/04 at 02:24 PM Reply With Quote
Camber is dead easy -- use a long sprit level and some wooden shims as packing 4mm is roughly 0.5 degrees.
Toe-in is more difficult --- you can get an approximantion using string and axle stands but it really needs to be set properly is some sort of gauge --- the "Trackrite" type work fine. Remember a book locost has colossal bumpsteer so set the toe-in under normal laden conditions -- with driver.
Corners weights use a pair of decent bathroom scales --they must be the same height and measure up to 150+kg
