Author: Subject: Noise coming from Rear Axle
Kitlooney1000
posted on 26/5/04 at 07:17 PM Reply With Quote
On long bends, left or right, I am getting a droning noise from what sounds like the rear axle, it stops after i straighten up.
Its a wide cortina axle, not touching anything that would cause and noise.
Any Ideas ?
Lew
[Edited on 26/5/04 by Kitlooney1000]
theconrodkid
posted on 26/5/04 at 07:26 PM Reply With Quote
could be a wheel bearing,mine makes a lot of noise as there is not a lot of bodywork to stop it so probly nowt to wory about
who cares who wins
pass the pork pies
posted on 27/5/04 at 06:40 AM Reply With Quote
Yes it sounds very much like a wheel bearing but check the propshaft or tyres aren't rubbing..
locoboy
posted on 27/5/04 at 11:12 AM Reply With Quote
i had a noise coming from the back of mine on left handers and it was only under accelleration, i could coast or cruise round it and there was no noise.
It turned out that the rear prop joint was just feathering the transmission tunel, a half turn on the panhard rod rose joint sorted it out in seconds.
Locoboy
Kitlooney1000
posted on 27/5/04 at 09:06 PM Reply With Quote
Nothing rubbing, but will try the panhard trick. if that doesnt work then i will wait until it gets louder and change the wheel bearings
thanks guys
Lew
