greggors84
posted on 2/6/04 at 05:40 PM |
Plastic Fuel Tank
I bought a tank from PTM quite a few months ago, i put it in the car the other month, and now i have noticed that there is a split in the top joint
and also there seems to be fuel leaking from the bottom of the tank. It is not a steady leak just a few drops. The petrol is quite brown though and
the fuel in the filter is quite brown too.
Any ideas what is causing the fuel to be brown, and where i can get the tank sealed up again?
Chris
The Magnificent 7!
posted on 2/6/04 at 06:49 PM |
have you asked PTM about it?
derf
posted on 2/6/04 at 07:33 PM |
Brown fuel, usually means that the tank is rusting, I know the title says plastic tank, but is there any metal in there that could be rusting? Is the
fuel system returnning, if it is could rust be carried back into the tank? How much dirt could be in the tank? Did they use a new sealant to seal the
inside of the tank?
stephen_gusterson
posted on 2/6/04 at 07:50 PM |
or considerably....
greggors84
posted on 2/6/04 at 08:23 PM |
I emailed PTM before i posted, but i wasnt sure if he was still doing the plastic tanks now, as i think MK use metal ones now. Wondered if anyone knew
why the fuel had gone brown.
Maybe considerably will know....
Chris
The Magnificent 7!
Mark Allanson
posted on 2/6/04 at 09:09 PM |
plasticisor or pigment leaching out?
Ben_Copeland
posted on 2/6/04 at 09:32 PM |
Anyone know what plastic they are made of ?
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
posted on 2/6/04 at 11:08 PM |
Black
I believe High Density Polyethylene is the answer you're looking for - may have a lining of Ethylene Vinyl Alcohol to make it non-porous (or it
that just for blow moulding?)
Anyhow - there is a feature on plastic tanks here: Plastic Tanks
Article
[Edited on 2-6-04 by Hellfire]
Ben_Copeland
posted on 3/6/04 at 08:05 PM |
Black
Funny f*cker...
Cheers mate
Ben
Roadster
