Author: Subject: self centering for sva
bobtatt
posted on 28/6/04 at 08:16 PM Reply With Quote
got sva in a little overa weeks time on my tiger avon havnt got any self centering at all anyone else come across this problem. the tracking is set to 1 degree toe in and the car drives well but no self centering what so ever. anyone got a solution for this problem as rest of car is just about right passed mot and ready to register once svad. cheers in advance rob.
posted on 28/6/04 at 08:30 PM Reply With Quote
Just before you go into SVA alter to "toe out" - we ended up at 5deg MK advise: wind it out as far as safely possible 3-4 threads on extensions. The car only has to attempt to return to centre from full lock left and right at about 10mph. Once through SVA with your pass, pull it back to parallel. 0 deg.
Most popular method me thinks
bobtatt
posted on 28/6/04 at 08:33 PM Reply With Quote
cheers for that will give it a go up and down the street tomo night.
Bob da builder
posted on 28/6/04 at 08:51 PM Reply With Quote
hey up,
also try reducing the front tyre pressure that will increase the friction and twist the wheel back, worked for me! 16psi seams to be the norm.....
p.s. in my case the car doesnt have to fully centre, just show attempt so dont worry if it doesnt snap back to straight. all the best
bob
[Edited on 28/6/04 by Bob da builder]
Viper
posted on 28/6/04 at 09:36 PM Reply With Quote
if you are using the avon top wishbones, they are not symetrical ie turning them over alters castor, castor helps self centering.
crbrlfrost
posted on 29/6/04 at 07:10 PM Reply With Quote
That would be my guess as well, a lack of caster. I don't like the idea of toe-out for testing and then returning to a non returning system. Kind of dangerous, not to mention inconvienent. Cheers!
NS Dev
posted on 30/6/04 at 06:07 PM Reply With Quote
I agree with the two posts above, the toe-out is ok as an emergency bodge but that is what it is!!
Check you have the top wishbones the right way up, then do you have any slack filled by washers between the upper wishbone bushes and the brackets on the chassis? If so then make sure the washers are all at the front of the bush and none behind it. On the bottom wishbone put any washers at the back of the bushes.
