posted on 11/10/12 at 02:47 PM |
Disconnecting brake pipes for a while...
When I do my back axle bearing & drum brake cylinder I will need to disconnect the brake pipe for a couple of days - I want to repaint the back
plate while it's off the axle, where the brake fluid has stripped the paint off.
Now I know the trick about fixing some plastic over the top of the master cylinder so that it's air-tight, to reduce the loss of fluid there.
I can't clamp a flexible hose, as the only one that's in this circuit is a braided pipe.
Does it sound reasonable to push flexible hose over the brake pipe flare, and put a bung in the other end of the hose?
And before anyone says it - I know I'll lose some fluid when I do this, and that I'll have to bleed the rear circuit when I've
finished.
Or does anyone have an alternative method they like to use?
mookaloid
posted on 11/10/12 at 02:54 PM |
How about a spare brake pipe fitting with a suitable size ball bearing to seat on the flare?
mcerd1
posted on 11/10/12 at 02:59 PM |
^^ thats what me and my dad always use
after 40+ years working on them my dad has quite a collection of old unions blocked off with either ball bearings or short bits of brake pipe folded
over
posted on 11/10/12 at 03:06 PM |
Recently changing the subframe in a tintop I had the same problem, the solution was standard female to female Brake pipe joiner fitting with a
bleed nipple screwed in one end. It was so handy I now keep a couple in my brake bits tool box.
BRAKE PIPE JOINER 2 WAY FEMALE CONNECTOR 10 X 1MM PK 5 | eBay
owelly
I have a few bits of brake pipe with the ends flattened and folded or soldered with the corresponding fittings, but I also use the '6mm bolt in
the end of a bit of rubber tube method' too.
http://www.ppcmag.co.uk
ChrisW
posted on 11/10/12 at 03:10 PM |
Why can't you clamp the braided hose? It won't affect it to be flattened; just make sure whatever you use doesn't damage the
braid.
Chris
My gaff my rules
designer
posted on 11/10/12 at 03:12 PM |
I use golf tees to block brake pipes when I work on them.
Slimy38
posted on 11/10/12 at 03:15 PM |
+1 to that.
posted on 11/10/12 at 03:18 PM |
braid.
Chris
It all depends whether the hose has a teflon tube inside - that type can't be squashed without breaking it. I think my hoses are that sort.
ChrisW
posted on 11/10/12 at 03:19 PM |
braid.
Chris
That's a new one on me! I've always just carefully clamped them. Never had a problem, but I guess I could have just been lucky!
Chris
My gaff my rules
posted on 11/10/12 at 03:20 PM |
I like that idea...
posted on 11/10/12 at 05:40 PM |
Take the cap off the master cylinder and put some cling film under it as well. If air can't get in fluid doesn't drip as much.
posted on 11/10/12 at 05:45 PM |
I said that in my original post!
In my case, it'll be a nitrile glove stretched over the top and held on with a rubber band...
posted on 12/10/12 at 08:46 AM |
Sorry I only read the title I use a crimped piece of copper pipe in a union same as all the others and it works for me.
aeromanboeing
posted on 16/10/12 at 08:13 PM |
I cant believe some of the dodgy things I read on this forum. Clamping off a braided line, Have you no brains. You crush the teflon inner hose and the
the stainless braid, Ok to clamp a rubber hose but then you bruise it anyway. Why not let the fluid drain out and replace it with new anyway. You
should do it regularly and anyway and you will need to bleed the system . If you cant afford new fluid you shouldnt be on the road anyway.OMG
mcerd1
posted on 16/10/12 at 09:10 PM |
^^^ steady on there
i happen to agree that clamping any kind of flexi is a bad idea in the long term, but you'd have to be crazy to let a brake system totaly drain
on any road car (race cars are a different story)
its much harder to blead a dry system, if you block off the ends off the pipes so you save most of the fluid it'll be much easier to blead
and when you blead it you'll flush 99% of the old fluid out anyway so whats the problem ?
[Edited on 16/10/2012 by mcerd1]
