Author: Subject: spinning wheel stud
beaver34
posted on 13/10/12 at 12:40 PM Reply With Quote
spinning wheel stud
hi,
ive got a spinning wheel stud, wheel is stick on the rear of the car carnt get to the back on the stud
any tips for getting it out?
loosing the will to live, tried putting some force on the wheel and nipping the stud but that hasnt worked, also lowered car down to load it up but that not worked either
thanks
blakep82
posted on 13/10/12 at 12:57 PM Reply With Quote
if you take the rest out, and pull hard on the wheel so the wheel sort of pulls on the stud, is that enough to jam the stud with friction? while you undo the nut, with a helper? or impact gun if you have one?
________________________
spiderman
posted on 13/10/12 at 01:03 PM Reply With Quote
Tack weld a bar on the end of the stud to stop it spinning then wind the nut as far back as possible and hopefully you will have enough room to get behind the nut to be able to cut the stud off, only works if you have open wheel nuts though.
Spider
loggyboy
posted on 13/10/12 at 01:13 PM Reply With Quote
Worst case scenario, remove the hub nut, if you have calipers remove them, then pull the whole wheel and brake combination off and work from behind.
Mistral Motorsport
beaver34
posted on 13/10/12 at 01:20 PM Reply With Quote
It's a axle to no hub but and carnt get the half shaft off for the wheel
I'll try borrow impact gun, wheel nut is longer than stud so not sticking out to weld onto, might have to dremel away at the nut to reveal some stud
PAUL FISHER
posted on 13/10/12 at 01:41 PM Reply With Quote
This is the method I used when I had the same problem on my Indy rear wheel stud, someone else pulling on the wheel with a long bar, at the same time I removed nut with my airgun
snakebelly
posted on 13/10/12 at 02:16 PM Reply With Quote
angle grind a slot into the centre of the nut as far as you can go, apply mr chisle to slot and give the good news with Tger Tool no 1, usually splits the nut quite cleanly, use the biggest chisle that will fit.
HTH
bi22le
posted on 13/10/12 at 04:36 PM Reply With Quote
HTH
This is what i did but its not as easy as it sounds. It took me and my friend all day.
Search for posts on here i had a 2 or 3 thread about it with lots of good ideas. I also posted my finished results.
Good luck. You cant give up, Whats the alternative ?!?
Please read my ring story:
renetom
posted on 13/10/12 at 05:09 PM Reply With Quote
stud
Hi
Split the nut as stated by snakebelly, by far the best method
The stud is buggered anyway.
Worked for me several times over the years, nice cold chisel & a good steel hammer.
get another stud & spot weld it on the back , Job done.
Good luck
MakeEverything
posted on 13/10/12 at 05:57 PM Reply With Quote
Originally posted by renetom
Hi
Good luck
+2
Kindest Regards,
Richard.
aeromanboeing
posted on 16/10/12 at 07:43 PM Reply With Quote
Some people should stick to production cars !!!
