Author: Subject: Uprights reconditioned. Cortina.
jossey
posted on 15/12/12 at 05:37 PM Reply With Quote
So i did the electrolysis thing a few month back and eventually got all my uprights done.
So from this for £40
Then 2 days per item in caustic soda n electrolysis n then hammerite spray.
New bearings.
And........
Got a bit of grease on the bottom arm....
I'm very pleased with the result. Total cost incuding the abive rusty urights n calipers, discs n pads, bearings, paint n soda is £86.00
David Johnson
johnemms
posted on 15/12/12 at 05:45 PM Reply With Quote
And while you have them in your hands...
Angle grind all the radius especialy the track rod ends for IVA
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
jossey
posted on 15/12/12 at 06:08 PM Reply With Quote
Oh poooo.
What should it look like to be iva ready.....
David Johnson
johnemms
posted on 16/12/12 at 10:00 AM Reply With Quote
Just put a nice radius on 'any' sharp forward facing edges..
TBH i only did the rod end..
Tester went straight for mine and found an edge 'lump' i had missed..
Gave me a file - sorted..
radius track rod end
The brake pipe brackets look good to use too.
I passed with 60/40 master cylinder.
M16 calipers
17.8 8" rear drum slave cylinders..
Brake stuff link
[Edited on 16/12/12 by johnemms]
