Author: Subject: Cleaning Cylinder Head After Valve Lapping
davidimurray
posted on 19/10/14 at 09:11 PM Reply With Quote
Duratec head is stripped, de-coked and valves are now lapped in. Everything is out apart from the valve guides. I've wiped all the valves/passages down over and over but wondered if there was anymore I can do to make sure everything is clean?
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
edthedrummer
posted on 19/10/14 at 09:50 PM Reply With Quote
Usually once I have lapped the valves in, and the cylinder head is ready to be re assembled, it goes back in the wash tank and has another thorough scrubbing. I flush the paraffin or cleaning agent through any and all oil ways, through the water jacket, and use small pipe cleaners on the guides and large ones on the ports.
It doesn't take long when you get into the routine and it can't ever hurt!!
19sac65
posted on 20/10/14 at 03:33 AM Reply With Quote
If youve not got a parts washer use a suitable container filled with some diesel and then as above
