Author: Subject: Gearbox end
posted on 15/4/02 at 08:07 AM Reply With Quote
Gearbox end
I've just heaved out the knackered old oil seal from the back end of my Type 9 gearbox. I have noticed that the splined shaft has a bit of side-to-side movement - is this normal?
Or do I have to take it to bits to repair a bearing...
theconrodkid
posted on 15/4/02 at 06:40 PM Reply With Quote
Yup the mainshaft bearing is a long way up the tube so about3mm each way is reasonable
posted on 15/4/02 at 07:49 PM Reply With Quote
I had a look at a cut-away drawing of a type 9 box - as you say, the last bearing is somewhere around the back of the gearbox proper.
That's a relief!
thanks,
