Northy
posted on 19/3/03 at 09:11 PM |
Clutch cable too long
I have tried fitting the standard Sierra clutch cable to my Vaux engine, ali bellhousing, type 9 box combo and it is atleast 1/2 inch too long
Any ideas? Any other cables I could use?
Graham
theconrodkid
posted on 19/3/03 at 09:20 PM |
can you put a spacer on the cable
who cares who wins
pass the pork pies
Mark Allanson
posted on 19/3/03 at 09:26 PM |
Can you make the lower outer cable mount adjustable? I once drilled the centre out of an M14 bolt (set screw)and put it through the outer cable mount
and put a nut on each side effectively making the outer cable variable length - copied it of a pushbike brake cable but on a bigger scale
Northy
posted on 19/3/03 at 09:58 PM |
Good ideas guys. I'll look at that tomorrow. Think I'll put a spacer at the pedal end and an adjster at the clutch end
Graham
