Author: Subject: Ford siera 1.6
P4
posted on 15/5/03 at 03:51 PM Reply With Quote
Ford siera 1.6
Hi
I have a Siera engine block whos bores measure 81.3 mm this equates to a 1.6 OHC LSD or LSE.
What do the letters indicate?
Is this a suitable engine for a book Locost?
Can a 5 speen box be bolted staight on?
P4
auzziejim
posted on 15/5/03 at 04:48 PM Reply With Quote
i have a 5sp type 9 box on my 1.6 pinto. hth
James
LoCostLancs
posted on 15/5/03 at 05:08 PM Reply With Quote
OHC - Over Head Cam
LSD - Limited Slip Diff
Sierra engine should be okay on a book spec car, I have a 5spd box on mine.
david walker
posted on 15/5/03 at 05:58 PM Reply With Quote
81.3 bore is later E-Max Pinto engine. This is basically a small bore 2.0 engine, ie same engine height and using a 2.0 crank.
No problem with type 9, 5 speed box.
Contrary to the advice in the previous post, I think you find it a tight sqeeze in a book chassis with a proprietary nose cone and scuttle. - Don't forget the MK Indy chassis which is popular is quite a bit taller than a book chassis.
Dave Walker, Race Engine Services - 07957 454659 or 01636 671277
