Author: Subject: Wishbone weld points
ecosse
posted on 29/11/06 at 07:55 PM Reply With Quote
As per pic below, I'm not sure whether I should weld up the end of the tubes where they finish at the BJ end and on the small vertical face of the plate to tube area, does it matter or make a difference to the strength of the part?
If yes to the tube ends, should these be flattened or should a small fillet be welded in, or again, does it matter?
posted on 29/11/06 at 08:30 PM Reply With Quote
The one shown in your diagram looks very similar to the lower front MK wishbone for the Indy. On the MK supplied item the plate si fully welded to the tube and the ends of the tube are closed with a weld bead.
HTH
t.j.
posted on 29/11/06 at 08:32 PM Reply With Quote
I'm going to weld it.
I had the same thoughts.
But as the weld isn't around the tube it will no or less influence to the strenght
The front of the tube will be in my case will be inserted by the mountingplate.
I don't want any water or something else into the tube so i'm welding it.
grtz
907
posted on 29/11/06 at 09:00 PM Reply With Quote
Hi
I welded round the ends of the gusset plate and cut half circles and welded in at 45deg. (see pic.)
HTH
ecosse
posted on 29/11/06 at 10:34 PM Reply With Quote
Thanks guys , weld it is then (hadn't thought about water getting in ) and the 45deg angle and fill method looks good.
Alex
NS Dev
posted on 30/11/06 at 08:45 AM Reply With Quote
when you finish the welds at the inner end (plate to tube) run them out away from the joint and onto the tube a bit.
Prob ott on this application but always good practice to run the weld out a bit to move the end of the heat affected zone away from the point of peak stress. (have a look at a JCB digger's rear arm next time you get the chance, look at the flange plates on them and how they fork out the welds from the ends of the plate onto the boom to prevent cracking)
[Edited on 30/11/06 by NS Dev]
ecosse
posted on 30/11/06 at 11:35 AM Reply With Quote
Originally posted by NS Dev(have a look at a JCB digger's rear arm next time you get the chance, look at the flange plates on them and how they fork out the welds from the ends of the plate onto the boom to prevent cracking)
Damn, I used to drive JCB's (long time ago) and always wondered why they did that
As you say may be overkill but can't harm anything, Cheers.
Alex
