Pdlewis
posted on 1/11/08 at 08:23 PM |
Seat Mounting
Hi,
I have a pair of triton seats (awsome) just wondering what the excepted way of mounting them is. They have 4 M8 mounts on the bottom but i think i
will need to raise the seat off the floor pan because i have a cross member in the way and im a sort ass so wouldnt be able to see over the steering
wheel if i didnt.
I though of a couple of options
1. Stack some squares of 6mm ali until the seat is the right height
2. mount the seat on some sort of ali box section
any other suggestions?
Build Photo Album
Updated 05/02/2009
graememk
posted on 1/11/08 at 08:34 PM |
rubber door stops might keep vibrations down too
Shamrock GS
posted on 1/11/08 at 08:49 PM |
I like the rubber bung idea. You could also use rubber exhaust bobbins if they have the right thread. Watch you dont lift them too high to fall foul
of the SVA seat height / Seat belt upper mounting measurement. (If you have yet to SVA that is).
Gary
Sun Tzu, The Art of War
twybrow
posted on 1/11/08 at 08:59 PM |
Why not fit some seat runners? They will lift your seat 25-30mm and you get the bonus of being able to move the seat....
mark chandler
posted on 1/11/08 at 09:22 PM |
I found to be comfy I had to raise the front of my triton seats by 1" at the front when mounting so they laid back a little.
I welded some angle between the chassis rail and TX tunnel and bolted directly to this.
thepest
posted on 1/11/08 at 11:25 PM |
Hey I just did mine this week. I fitted runners on the drivers side (ford fiesta ones).
I raised the seat on the pax side by using 2" box section. One side to bolt into the seat and another that bolts into the floorpan.
Driver side required some creative welding brackets to fit the runners to the seat.
I used a 3mm rubber sheet where the seat attaches to any metal to keep the fibre from cracking and to also get some damping from vibrations.
LBMEFM
posted on 2/11/08 at 09:48 AM |
I am now about to fit my seats and I think the obber bung/bobbin idea sound brill, anyone else done this?
maartenromijn
posted on 2/11/08 at 09:56 AM |
I will mount my Tritons with 20mm spacers, made from some Nylon.
If needed, I will raise the front a bit to make it comfy.
BLOG: http://thunderroad-super7.blogspot.com/
stuart_g
posted on 2/11/08 at 12:22 PM |
I have MNR seats but the same fixing arrangement.
I fitted Cobra runners then Marc at MNR supplied me with some aluminium stand offs to go between the seat runners and the floor just high enough to
clear the chassis tube, I then have a 50mm washer on the inside and underside of the floor to spread the load. No probs so far.
