ChrisW
posted on 30/3/04 at 10:32 PM |
Trailer design
Been thinking about this for a while and just wondered what you lot thought...
Want a car trailer to pull with my Cabrio. It's not the best made car in the world so I'd like to take as much of the load off the tow
bar as possible. So... why not have a trailer with a wheel in each corner? Obviously the front wheels would either need some kind of steering
arrangement or a rotating bogey and it would be a right pain to reverse but apart from that is there any reason why it's not done? As far as I
can see it would relieve all the vertical force on the tow bar and, with a decent braking system, should put far less stress on the car whilst
towing.
The scenery trucks at work are like this but obviously they only get pulled around the various stores and the studios. They're certainly big
things and take a lot of weight tho'.
Your thoughts...?
Chris
My gaff my rules
JamJah
posted on 30/3/04 at 10:40 PM |
I dont see it be a problem. Farm trailers are often 6 axle beasts with the first axle mounted as far forward as reasonally possible.
Nosey bit... Where do you work? Thought you were an ISP but obviously got that wrong!
Viper
posted on 30/3/04 at 10:56 PM |
That kind of set up is called a drawbar whether that is classed as a trailer you can tow with a car is beyond me, if you have a properly balanced
trailer the nose weight will not be excesive anyway, check you cars handbook it should tell you what kind of weight you can put on your tow bar.
Mark Allanson
posted on 30/3/04 at 11:00 PM |
If you try towing anything with a PugSkip, you will find the door gaps opening up a bit. Pininfarina or no Pininfarina!
Spyderman
posted on 31/3/04 at 03:06 PM |
With the axles separated to the front and rear it would then become an articulated vehicle and would require an HGV licence.
The only way around that is if it is classed as an agricultural vehicle.
Spyderman
A Badger
posted on 31/3/04 at 10:22 PM |
Your not saving much by separating the axles, most trailors only put 70kg of nose weight on the tow hook, any more is unsafe.
You'll still get the same pulling forces which ever way you do it and they are the bigger ones.
Andrew
andyps
posted on 2/4/04 at 08:57 PM |
I would think that a standard 4 wheel trailer would be OK - as long as the car on the trailer is placed correctly the nose weight should be low (but
you do need some nose weight).
Just make sure you load the car when the trailer is not connected to the Pug - nearly had the back of my car off the ground once when doing this!
Fifer
posted on 2/4/04 at 09:25 PM |
Max ball hitch weight by law is 70kg as sugested above.
Ideal is 40 - 50 kg, this is nothing (get an eight stone person to stand on the ball, thats it) No less than this or you'll look like some of
the caravan Bozzo's with the rear end of the car 15 inches in the air and swerving all over the road.
If you get the trailer nose weight right, with a braked twin axle trialer, you wont know it's there !
By the way, wheels at each corner is a no go.
