Mr Whippy
posted on 26/4/12 at 09:09 AM |
A rather different Locost...possible project?
Hi
I have just acquired (for free) another landy, a series 2 swb, unfortunately this one is a right wreck, chassis is totally nuked, running gear well
worn…oh dear just a spares car
So was thinking of what to do with it then I saw this –
Aha! That looks fun but yikes its aircooled vw based, could not be bothered with that poopy power and vw parts are super expensive now also a standard
beetle chassis has a wheelbase about 10 inches too long (landy’s are actually very small cars btw)
So I’m thinking what else would work with a landy shell, how about a 7! Using Google sketchup and warehouse models it looks like it would all fit,
probably a wide body locost would give more leg room but all in all it seems to work well. A bit of extra spaceframe out to the standard aluminum
bodywork, but easy to do
I have a 2.8 v6 in the garage…Scorpio hubs and brakes, replica lambo wheels…ho ho ho scary
With all that body work covering everything and the standard landy lights even putting it through an IVA looks simple!
I think it would be hilarious fun
Daddylonglegs
posted on 26/4/12 at 09:16 AM |
Why not?
It's got built-in crumple zones too
iank
posted on 26/4/12 at 09:31 AM |
Have you stopped taking the little purple pills?
Mad a a box of frogs, but no reason why you couldn't make it work.
Anonymous
Bluemoon
posted on 26/4/12 at 09:33 AM |
You willl only see the dash from the seating postion... Way to low...
Benzine
posted on 26/4/12 at 09:36 AM |
slammed land rovers can look awesome.
see here
HomersDouble
posted on 26/4/12 at 10:02 AM |
Surely that will upset the beautifully aerodynamic qualities of a seven......
HowardB
posted on 26/4/12 at 10:52 AM |
wrong, wrong, wrong!!
but then I am biased!
Howard
Ivan
posted on 26/4/12 at 10:53 AM |
I like you thinking
posted on 26/4/12 at 11:03 AM |
A +4 inch width chassis would be a better fit I suspect.
StrikerChris
posted on 26/4/12 at 11:47 AM |
You'd be sat in the pickup tho,behind the cab! I nearly bought a fiberglass Mk1 Escort shell to put on mine until I realised your sat on the
back axle....
Mr Whippy
posted on 26/4/12 at 12:43 PM |
your right about the seating position, its about 7 inches further back than in a landy.
To see over the dash all I'd do is raise the seats and move them forwards compaired to those in a normal 7, really much more like how you sit in
a landy rather than with your legs straight out as in the normal 7, the sides of the 7 chassis in effect become more like large sills. If you look at
the seating in the model I have moved them to roughly the correct position
[Edited on 26/4/12 by Mr Whippy]
Mr Whippy
posted on 26/4/12 at 12:45 PM |
yeah I think you right I'll look into the dimensions for that, ta
MakeEverything
posted on 26/4/12 at 12:48 PM |
see here
I love that. Initially, i was thinking No! - Try a custom snatch landrover or something but then i saw benzines link!
Skip the seven chassis, make a box chassis to fir the body, fir a large V8 with side exit exhausts, and turn it into a street rod.
Kindest Regards,
Richard.
