Author: Subject: IVA- How much does the inspector want to see
davidimurray
posted on 27/10/13 at 06:41 PM Reply With Quote
Out of interest, how much does the inspector want to see and what will he expect to be removed. Just wondered as I've covered the area under the dash and it is easy to remove but a real pain to refit. Will he want the tunnel top removed? To remove mine is a pain as I have a bolt hidden under the dash. I have photos of all these 'hidden' areas which I will take with me.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
pekwah1
posted on 27/10/13 at 06:50 PM Reply With Quote
I think photos will be ok.
My inspector didn't want me to remove anything.
Lots hidden behind the dash he couldn't see, as for the tunnel, he could see everything he needed from underneath while it was on the lift!
Where are you getting tested?
skov
posted on 27/10/13 at 06:53 PM Reply With Quote
All my inspector asked me to remove was the bonnet and rear tub cover.
He did have a good look down the tunnel from the openning at the diff end.
theprisioner
posted on 27/10/13 at 07:06 PM Reply With Quote
The IVA man (Livingston) did not ask me to remove anything. However I had extensive pictures with me of all the hidden areas just in case. I guess if he get's suspicious about any issue he can as you to remove stuff!
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
davidimurray
posted on 27/10/13 at 07:27 PM Reply With Quote
I'm being tested at Llantrisant (Cardiff), so fingers crossed he won't want anything removed- it's all doable just a question of how awkward.
Thanks for the replies.
Dave Bailey
posted on 27/10/13 at 08:03 PM Reply With Quote
I had to remove my under dash cover so that he could look at the column mounts... Mainly because I have an adjustable column... To be honest if it is going well you won't care about having to remove some panels.... Feed his ego and you'll be surprised how much you get away with....
Dave B
daveb666
posted on 28/10/13 at 08:19 AM Reply With Quote
Didn't remove any panels (under dash or otherwise) and didn't get ask to see any photos either.
wicket
posted on 28/10/13 at 12:55 PM Reply With Quote
Apart from the bonnet, just one wheel nut to prove number of threads engaged.
