Author: Subject: 4 link suspension
Minicooper
posted on 11/10/15 at 03:05 PM Reply With Quote
4 link suspension
Because of packaging ideally I would like to angle the links in at about 9 degrees in plan view, this would not be to locate the dedion laterally, there will be a watts linkage to do that
I can't think of anything that would stop it working but I would ideally like confirmation before spending time and money
Dingz
posted on 11/10/15 at 09:47 PM Reply With Quote
You would need to use rubber bushes to give some compilance to allow movement.
went on and on.
DIY Si
posted on 14/10/15 at 03:56 PM Reply With Quote
As said, the geometry would lock solid/induce quite high stresses unless the bushes allowed the twist that would occur. Otherwise, it's doable.
Sun Tzu, The Art of War
