Author: Subject: Coil spring compressors
ethomas
posted on 23/10/05 at 10:43 PM Reply With Quote
I am now thinking about stripping the suspension in my kit car and fitting all the deflex bushes I got last week (as well as generally making sure things are ok). I will need a pair of spring compressors for this, and have found several on eBay for about £10 (eg this).< br />
Would this be up to the job? Alternatively is there a true locost approach which works jst as well?
Ed
posted on 23/10/05 at 11:33 PM Reply With Quote
You don't need spring compressors if you aren't removing the springs. You can remove the strut or damper with them still under compression.
ethomas
posted on 24/10/05 at 12:21 AM Reply With Quote
I am going to be removng the wishbones, which according to Haynes (it is a Cortina front subframe) requires the springs removed,
mark chandler
posted on 24/10/05 at 08:06 AM Reply With Quote
Cortina springs in a standard subframe are under a lot of tension even on full droop. Get some decent ones or hire some if this is a once off.
Regards Mark
dave-69isit
posted on 24/10/05 at 11:45 AM Reply With Quote
spring compressers
mine only cost 16 quid for the pair from motor factors heavey duty made by drapper cheeper than hireing them
dave-69isit
posted on 24/10/05 at 11:47 AM Reply With Quote
spring compressers
you could borrow them if you are not to far away from brum,
ethomas
posted on 24/10/05 at 04:09 PM Reply With Quote
Thanks for the offer, I am unfortunately in Aberdeen
I think I will pop along to the local motor factors and see what they have on offer. I would rather buy than hire as I anticipate doing this again on other cars in the future.
Thanks for the help,
Ed
