Author: Subject: harnesses - opinions required
AdamR
posted on 28/12/07 at 07:47 PM Reply With Quote
Been playing around with my upper harness mounts today. I understand (I think) that the belts are not supposed to wrap around the edge of the seat when tightened, but looking at a few pics of other cars it seems lots of people have got away with it at SVA. Perhaps I've got the rule wrong? Even if my seats had harness slots the deflection would still depend on how tall the bloke sitting in the seat is.
Here's a pic of mine, which are slightly deflected when I'm sitting in the seat. Is this ok? And what is the SVA requirement exactly, and how is it enforced?
harnesses
harnesses
PS. Anyone know where I can download an SVA manual? This issue proves I need to get one.
[Edited on 28/12/07 by AdamR]
RazMan
posted on 28/12/07 at 08:35 PM Reply With Quote
Sorry to say it but I think you will have to move the mountings further apart to prevent the belts rubbing on the seats.
Raz
nitram38
posted on 28/12/07 at 08:37 PM Reply With Quote
It will be a whole load of hassle I am afraid
When your belt straps pull down on the seat, the seat it'self becomes part of the restraint system and then the seat has to be tested too.
That is why most people move the top mounts to suit.
blakep82
posted on 28/12/07 at 08:52 PM Reply With Quote
http://www.rootpeg.net/SVAMarch2004.pdf
________________________
RichardK
posted on 28/12/07 at 08:59 PM Reply With Quote
You could always put a horizontal across your hoop with some threaded inserts through it and attach your harnesses that way.
Personally I would risk it
Rich
Gallery updated 11/01/2011
AdamR
posted on 29/12/07 at 10:05 AM Reply With Quote
OK, thanks for the replies so far.
Don't want to simply raise the mounting points as the straps are supposed to slope upwards towards your shoulders to hold you down in the event that you're upside down.
Making the mounts wider is also problematic as the belts would have a tendency to slip off the shoulders.
Hmmm.... more head scratching required yet I think.
Aico
posted on 29/12/07 at 12:41 PM Reply With Quote
The seat isn't made for a harness. The result of this is right there as you can see. Maybe you can make slots? I'm not sure if you have enough room to do so. This way there would be no side deflection anymore.
steph
posted on 29/12/07 at 09:46 PM Reply With Quote
HARNESSES
hi there if you still want to download the sva manual go into RHOC&R which is the robin hood site and you can download it from there cheers
