Author: Subject: prop
jay taylor
posted on 11/4/06 at 07:55 PM Reply With Quote
prop
building gts locost using an mt75 gearbox has anyone else used one of these and if so do you have pics of
your prop just so i know what i should be asking for when i get one made thanks in advance
nludkin
posted on 11/4/06 at 09:02 PM Reply With Quote
Looks like you are using pretty much the same type of setup as myself although I have a gts w7de chassis.
There are 2 types of output flange on the MT75, the one I have has 3 outer pins and a centre pin with a diameter of 19mm. The second, is, well, different..
The flange on the sierra diff is standard and most propshaft manufacturers will not need any more information.
So, the only information I needed to give was, MT75 (3 pin) to Sierra diff and the length of the propshaft needed.
Also, the prop you need made will have 2 universal joints on because you need more flex than you get with the rubber "bung" that the donor sierra had.
If you give Martin at Proptech a ring he will be able to make a really good prop for you for about £120. They are really nice to deal with and make props for Westy and Caterham.
Proptech Ltd, Nr Kidderminster. (01299) 251247
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 12/4/06 at 08:10 AM Reply With Quote
Dont know if these will be any good?
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/4/06 at 08:11 AM Reply With Quote
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/4/06 at 08:12 AM Reply With Quote
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
posted on 12/4/06 at 08:13 AM Reply With Quote
If you want any more pictures i could take a some more as i have only just stripped the parts from my sierra.
nludkin
posted on 14/4/06 at 09:39 PM Reply With Quote
I have added pictures of the propshaft I am using to my photos. Propshaft Photos
