cps13
posted on 10/4/13 at 05:43 PM |
Wilwood handbrake caliper
I have a wilwood handbrake caliper - for solid discs. Never used - only taken out the box to find it won't fit on my build! Then stupidly left
it sat around rather than sending it back!
linky
£100 posted.
roohunter
posted on 12/4/13 at 08:47 PM |
Is this just for the one caliper
cps13
posted on 12/4/13 at 09:36 PM |
Yep. I bought one to see if it would fit.
greavesy7
posted on 12/4/13 at 10:06 PM |
Caliper
What were you fitting it to ??
cps13
posted on 12/4/13 at 10:31 PM |
I've got a custom built chassis with a mixture of westy and MK Indy. It is MK Indy with IRS but the Caliper mounting brackets I had turned out
to be for sierra calipers. You can get the mounting kit to fit MK Indy for the calipers from rally design. I just thought seeing as I already have the
sierra brackets an handbrake and cable I will stick with that route.
cps13
posted on 15/4/13 at 07:22 PM |
bump. £90 delivered.
cps13
posted on 8/5/13 at 09:09 PM |
bump
