Author: Subject: Wanted for my Zetec installation
andy_mullin
posted on 19/12/07 at 10:12 AM Reply With Quote
• A set of bike carbs or throttle bodies.
• Inlet manifold
• Flywheel and clutch for Zetec to Type 9 box
• Exhaust Manifold (Striker-Zetec)
paulf
posted on 19/12/07 at 09:15 PM Reply With Quote
If you use an 1800 engine the flywheel and clutch cover will couple to the type 9 box , you will need a clutch plate with the 1 inch 23 spline centre though , i think early mondeos and some of the escorts fit.
Ae engine will also need a water pump from an 1800 escort engine as the 2 litre one rotates backwards.
Paul.
