Author: Subject: wanted: ideas for wiper bezel tube
stevegough
posted on 1/7/10 at 10:17 PM Reply With Quote
Just got a set of "longer" mini wiper boxes from CBS to improve the angle the wipers make with the screen.
I now need two short lengths of thick - wall plastic tubing to make the bezels to produce the angle I need. This tube needs to be 28 / 30mm outside diameter and 15mm inside.
Or any other ideas would, of course, be gratefully received as always. Rescued attachment make-windshield-wiper-bezel-200X200.jpg
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
stevebubs
posted on 1/7/10 at 10:32 PM Reply With Quote
Find plastic pipe with the outside diameter you need.
Cut copper pipe to length, and wrap with electrical tape until tight fit in above.
Add sikaflex to seal and solidify
stevebubs
posted on 1/7/10 at 10:33 PM Reply With Quote
Option 2 - Get some 30mm bar, and get someone with a lathe to make them from metal..
stevegough
posted on 2/7/10 at 06:29 AM Reply With Quote
Thanks for those ideas, "Reading Steve" sounds like a good idea - I had a go with the old Sierra handbrake sleeve last night which was nearly ideal except the outside is ribbed!
Luego Locost C20XE.
r1_pete
posted on 2/7/10 at 06:57 AM Reply With Quote
How about THESE
posted on 2/7/10 at 07:20 AM Reply With Quote
Originally posted by r1_pete
How about THESE
They tend to be over different lengths and different angles so it might be a case of trial and error until you find the right ones.
posted on 2/7/10 at 08:39 AM Reply With Quote
Make some from dowel like a brush handle drilled down the middle and use them to make a mould then cast them in resin or mouldable plastic.
Bluemoon
posted on 2/7/10 at 09:27 AM Reply With Quote
I used caterham ones (not sure they will give you the angle you want mind!)..
Dan
