Author: Subject: Blue silicone hose
greavesy7
posted on 6/12/14 at 05:30 PM Reply With Quote
Blue silicone hose
Does anybody have any blue silicone hose knocking around the garage either 32mm and 11mm Id
samjc
posted on 7/12/14 at 08:21 AM Reply With Quote
What lengths as i have 32mm i belive but ill check. I mainly have bends
greavesy7
posted on 7/12/14 at 10:01 AM Reply With Quote
About 3 " would do it
davidimurray
Drop Eddie99 a u2u - he was having a clearout recently.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
samjc
posted on 7/12/14 at 11:32 AM Reply With Quote
Ill check this afternoon.
tims31
posted on 7/12/14 at 03:36 PM Reply With Quote
Hi Samjc,
If greavesy7 doesnt ant any of the 32mm bends i'm after some. If you have any i'll let you know what i need.
Build: http://www.martinsfurybuild.co.uk/
Volvorsport
posted on 7/12/14 at 03:39 PM Reply With Quote
I've got quite a bit of s/hand stuff....90/45 degree and straight.
www.dbsmotorsport.co.uk
getting dirty under a bus
tims31
posted on 7/12/14 at 03:48 PM Reply With Quote
Great, I'll have a look at my rad and engine tomorrow and let you kno what I need if thats ok? Can't get to it till tomorrow.
Volvorsport
posted on 7/12/14 at 04:14 PM Reply With Quote
I've got it to hand.. I've got a beading machine if you need the ally doing too.
samjc
posted on 7/12/14 at 06:55 PM Reply With Quote
No problem just let me know as got a bag full of bits just needing more ali tube as all mines just for connecting.
tims31
posted on 10/12/14 at 02:23 PM Reply With Quote
apologies for taking so long to respond I've been trying to work out how best to show the configuration I am trying to achieve.
Anyhow, hopefully the attached images explain what I need and you can tell me what you have or if it can be done.
So what I think I need is:
two 32mm 90 degree hoses
a metre length of 32mm straight hose
One hose with about a 120 degree bend with one end 35mm and another 32mm if possible or 35mm if not
One 90degree hose ith one end 35mm and the other 32mm if possible or 35mm if not
500mm ali tube with a bead on each end
The first image shows a rough guide of what the layout should be and the others roughly what I need.
bottom-hose-layout
bottom-hose-layout
top-hose-layout
top-hose-layout
samjc
posted on 11/12/14 at 01:37 AM Reply With Quote
Will double check but belive all mine to be 32mm. Got a few 90° bends will get a picture and details of other bits i have.
tims31
posted on 11/12/14 at 09:18 PM Reply With Quote
Great, thanks very much.
Dooey99
posted on 13/12/14 at 01:16 PM Reply With Quote
thats exactly the same setup as i have on my 7 but i dont have the heater matrix it works a treat, i got all my hose and pipe from Auto Silicone Hoses. prices were very reasonable. all though i do know from another experience that old hoover pipe works well like when you get all those extensions with your vax that make it like 3 miles long yeah... i used them on another car i done instead of buying 32mm pipe not thats its expensive i just had it to hand.
Less weight more speed, more power more speed
If in doubt, give it a clout
samjc
posted on 13/12/14 at 07:20 PM Reply With Quote
Tim31 u2u sent.
tims31
posted on 15/12/14 at 07:30 PM Reply With Quote
Replied Sam,
What I am trying to achieve looks a bit like this although not quite to the correct scale.
Rad-bot-hoses
Rad-bot-hoses
mk85
posted on 16/12/14 at 11:01 AM Reply With Quote
Try looking on amazon there's loads on there and very well priced
