Author: Subject: coupling nut
Cita
posted on 7/10/05 at 08:48 PM Reply With Quote
coupling nut
I'm looking for a coupling nut or whatever it may be called of 5/16" unf. and a 40 mm long full thread matching bolt.
It is used to couple two threaded rods together via the long nut.
It's impossible to get hold of in this retarded country
Thanks!
Danozeman
posted on 8/10/05 at 08:13 AM Reply With Quote
could u not get one turned up or get a long nut with the smaller thread u are after one end and drill and tap the other?
Dan
Cita
posted on 8/10/05 at 08:40 AM Reply With Quote
Yes I probably could do all this but why going through so much hassle for a 1£ nut ?
I can hardly imagine that there is no place in England where a 5/16" unf coupling nut is available.
After all,you are the guys with the funny nut sizes
BKLOCO
posted on 8/10/05 at 09:41 AM Reply With Quote
I'm sure my nuts are a normal size!!!
Not that I've done any checking you understand.
mad-butcher
posted on 8/10/05 at 06:31 PM Reply With Quote
can you not get hexagonal bar over there and make your own. failing that if it's not under pressure get a short lenght of tube and weld a nut on either end. i think some early fords had something similar on the exhaust manifold to act as a standoff for a bracket.
tony
Cita
posted on 8/10/05 at 08:56 PM Reply With Quote
I dont think I would ask it here if I could make my own but one never knows
Machinework is around 25£/hour or something like that overhere so that coupling nut would be very expencive I think.
cheers Cita
BKLOCO
posted on 8/10/05 at 09:45 PM Reply With Quote
If you are up for it I'll make you one on Monday and swap it for a bottle of that lovely Trappist beer you have over there.
Does it have to be hexagonal? not sure we have any material but could make it from round with a couple of flats.
Cita
posted on 9/10/05 at 06:42 AM Reply With Quote
THANKS MATE !!!!
You have U2U
wilkingj
posted on 9/10/05 at 08:49 AM Reply With Quote
Ahhhh... BEER TOKENS... the Universal Locoster Currency
Best Regards
Geoff
http://www.v8viento.co.uk
BKLOCO
posted on 11/10/05 at 11:09 AM Reply With Quote
It's in the post!!
Cita
posted on 11/10/05 at 12:47 PM Reply With Quote
JEEZ BKLOCO,
have you have nothing else to do?
Million THANKS man!!!!
Cheers Cita.
