kastrato
posted on 2/10/07 at 09:33 PM |
quick steering rack
Hello here,
I havea sierra based mk indy ( I bought it all ready built) and has a very "long" steering rack (I have fitted a small steering wheel) and
I need almost 4 turns from side to side which is alright for road use.
I usse the car only on track (circuit) and I needa short steering rack (2.4 turns)
I have found 2.4 steering racks from escorts etc but not from a sierra.
Would an escort steering rack fit my sierra donor MK?
Any suggestions on where can I find one in a reasonably price?
Thanks in advance
MK INDY fireblade
bigrich
posted on 2/10/07 at 09:47 PM |
quaife do a rack and pinion kit for the sierra rack though its a 2.8 turns lock to lock not a 2.4 £89.00 on their website although you will need to
fit this to your existing rack assy and it may require shortening aswell to fit the shortened rack on the mk
kastrato
posted on 2/10/07 at 09:59 PM |
and how all that shortening can be carried out ?
by cutting it and weld it again?
is this quaife kit the same for all sierra racks or I need to specify exactly which I ve got.
I would preffer a new one which fits without any additional work just plug and play really..
MK INDY fireblade
Arnie
posted on 3/10/07 at 05:54 AM |
Try MK I think they sell modified quick racks.
Regards,
Arnie
Paul TigerB6
posted on 3/10/07 at 09:32 AM |
Its on the MK price list - Sierra quick rack £125
posted on 3/10/07 at 10:02 AM |
MNR also do one... we got ours from there.
kastrato
posted on 3/10/07 at 10:15 AM |
Thanks guys appreciated!
MK INDY fireblade
posted on 3/10/07 at 10:24 AM |
But bear in mind if you have a small steering wheel and then fit a quicker rack the effort required to steer will be higher....
Probably not a problem but worth bearing in mind!!!
mad-butcher
posted on 4/10/07 at 08:44 PM |
No it's not cut and weld, the rack is shortened by the required amount on I think from memory the left hand side then a new hole is drilled and
threaded to take the rack extention,being case hardened not a DIY job
Tony
kastrato
posted on 5/10/07 at 02:12 AM |
I dont mind the steering to become harder cause I am using the car only on track so no problem there..
I do mind to cross my hands twice in order to avoid spin though... if you know what I mean...
MK INDY fireblade
Toady1
posted on 9/10/07 at 11:29 AM |
lol! I know what you mean! I think im gonna give MK a ring to get mine!
[Edited on 9/10/07 by Toady1]
