Author: Subject: can anyone id this bolt marking please?
DanP
posted on 22/3/11 at 07:19 PM Reply With Quote
Just got some new harness bolts from europa that have this marking on that I have never seen before, and wanted to check out the bolt specs before i trust my life to them.
Has anyone ever seen this marking before and/or know what it means??
Thanks,
Dan
crazy bolt symbol
crazy bolt symbol
bi22le
posted on 22/3/11 at 07:25 PM Reply With Quote
Dont know TBH but they look cheap!!
Please read my ring story:
HowardB
posted on 22/3/11 at 07:28 PM Reply With Quote
never seen anything like that before. but surely the bolts need to be to BS spec, or similar,...?
hth
Howard
skodaman
posted on 22/3/11 at 07:38 PM Reply With Quote
It's the Chinese character for ,'Made in Shanghai from best quality chocolate.'
Skodaman
jollygreengiant
posted on 22/3/11 at 07:42 PM Reply With Quote
I think S denotes, High Tensile Imperial Thread. It's just larger than normal. Or its just manufacturers symbol.
adithorp
posted on 22/3/11 at 07:47 PM Reply With Quote
S is safety and you'll find it on a lot of old seatbelt bolts which are usually imperial sizes (7/16th UNF?) with a shallow head (alot aren't marked at all). I've never seen it marked like that though; Usually just a plain S. I used bolts from an old tin-top that only had S on them and my tester asked for a second opinion, which was that it was OK.
If I remember correctly the old SVA manual had a list of min requirements and a proviso that unmarked bolts supplied with harness' were acceptable
http://jpsc.org.uk/forum/
jacko
posted on 22/3/11 at 07:49 PM Reply With Quote
Same as what came with my seat belts Sabelt and passed ok on SVA but don't know about IVA
Jacko
welderman
posted on 22/3/11 at 08:59 PM Reply With Quote
Yep sabelt bolts. Mine failed and they needed a certificate. So just got new bolts with 8.8 on
Thank's, Joe
I don't stalk people
DanP
posted on 22/3/11 at 11:24 PM Reply With Quote
Thanks for the answers, sounds like I need to ring Europa tomorrow to see if they have anything to prove the grade otherwise I'll be sending them back.
Dan
matt_gsxr
posted on 22/3/11 at 11:28 PM Reply With Quote
take the receipt to IVA with you maybe?
blakep82
posted on 22/3/11 at 11:30 PM Reply With Quote
i'd just go for some 7/16" cap head bolts. almost always 12.9 grade, and even if they're not marked, they'll pass anyway as its very rare to find any less than 12.9
________________________
