Author: Subject: Start of tube die. Just because you can does not mean you should!
AdrianH
posted on 27/12/12 at 10:49 PM Reply With Quote
I was getting bored so needed some time in the workshop/garage, project would be a home made tube bender, on the cheap!
Looked around my metal pile and found some 10mm plate and some old rusting metal around 18mm thick, formed a sandwich with 3 x 10mm pieces approx 200mm square and then 2 x 18mm pieces across diagonally. Drilled for 6 10mm bolts and one big hole at 1" diameter for the pivot point.
Lots of work on the band saw to rough cut and then down to the job of rounding the piece to a 100 degree quadrant. I completely trashed a dividing table, just was not big enough for the job as I ended up breaking the gears, so had to improvise.
This was my answer.
Milling tube die 1
Milling tube die 1
Milling tube die 2
Milling tube die 2
I had to take breaks from the job to allow the feelings to settle back in my arms and fingers. And to think I should know better being H&S trained.
The next step is to rough cut the groove in the blank before finish cutting. At this rate in a week or so.
Adrian
[Edited on 28-12-12 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
posted on 27/12/12 at 11:09 PM Reply With Quote
Loving the effort! Remind me how much it costs to just buy one though
AdrianH
posted on 27/12/12 at 11:16 PM Reply With Quote
Well at the moment one can go on to ebay and buy a cheap hydraulic set with 5 dies for £349 including delivery.
If you don’t believe me check this out. eBay Item
I will just be doing the 1 3/4" die as that is 45mm for roll cages.
That is why I say just because you can, sometimes locost can be more expensive. Still a challenge though!
Adrian
splitrivet
posted on 27/12/12 at 11:28 PM Reply With Quote
Just made my roll bar with a dry bollock bender from machinemart filled with sand, also made the crash bars for my bike by the same method. Nice to build it yourself though.
Bob
AdrianH
posted on 27/12/12 at 11:35 PM Reply With Quote
I have a 12 tonne unit sat in the garage with all the dies, how did you find the fit on tube and what size did you use?
Would also like to know just how much deformation you had, or oval-ling if you know what I mean.
Adrian
p.s.
I still find the bounce very hypnotic!
[Edited on 27-12-12 by AdrianH]
spiderman
posted on 28/12/12 at 12:10 AM Reply With Quote
I have wasted so much time through being hypnotized! Never seem to get tired of it though.
I find using the die one size down on the 12 tonne hydraulic bender helps stop ovaling and tube collapsing as the dies are sized for internal diameter pipe and not outside diameter tube. I also cut a piece of the tube I am bending lengthways and place that between the tube and the rollers on the bender with plenty of grease, this stops the rollers denting the tube being bent.
Spider
Spider
splitrivet
posted on 28/12/12 at 08:20 AM Reply With Quote
Adrian
p.s.
I just ignored pipe size on the die and used the tightest die, there was no deformation. There are lots of videos on tweb regarding the sand method, it was how they did it back in the old days and it worked for them.
Bob
[Edited on 28/12/12 by splitrivet]
posted on 28/12/12 at 09:11 AM Reply With Quote
If you cut the inner pieces down before you bolted them together would it give your mill a bit of a start with less to remove ?
The jogger is from the movie Click
trikerneil
posted on 28/12/12 at 09:38 AM Reply With Quote
I used a similar method only using my lathe.
The large die was steel and cut with three different radii. I then cut it into 120 degree segments.
It took a while but worked OK.
Neil
ACE Cafe - Just say No.
AdrianH
posted on 28/12/12 at 11:30 AM Reply With Quote
trikerneil
I have done some work on dies in my lathe previously, using 6" dia steel bar and made dies for 3/4" and 1" tube
I could not get hold of 12" diameter piece at a reasonable price to start with so gave up on that idea. I do like what you did with then going to three 120 degree segments, that is very good lateral thinking.
Even did one for 1" Square tube, but not very successful on a 3" radii. Needed to fit the internal 'hump' to ridge the inner face along the tube.
[U]Peteff[/U]
I thought it best to keep it all in register. I had a little dos program written for me years ago that calculated individual cuts to rough out the shape first before finishing, I have a few slitting disks or thin cutters with round cutting profiles, one is 4mm thick and the other is 3/16" thick. So cutting will be done in slices to start with. Need to weld up the fixture to hold it as it is presently just welded in place and I am getting some movement.
Adrian
AdrianH
posted on 4/1/13 at 12:34 PM Reply With Quote
Just an update
I have sort of finished machining the die, may need a bit of emery work, but will do for a starter.
Tube Die 1
Tube Die 1
Tube die 2
Tube die 2
Will have to do the frame next and see how bits go together!
Adrian
AdrianH
posted on 12/1/13 at 09:44 PM Reply With Quote
A few pictures.
I got bored, it's not finished yet, but I had to try and see if it would work, well you would wouldn’t you?
Built up the frame and cut a few guides out of aluminium block, placed things together and had a bend!
tube guides
tube guides
Dieframe2
Dieframe2
Trial bend start 1
Trial bend start 1
Trial bend start 2
Trial bend start 2
Trial bend start 3
Trial bend start 3
The guides are just sat on a base plate as could possibly be seen.
Adrian
AdrianH
posted on 12/1/13 at 09:47 PM Reply With Quote
So started to bend.
process1
process1
process2
process2
process3
process3
process4
process4
I ended up over the 90 degrees with spring back so need to work that out.
Adrian
AdrianH
posted on 12/1/13 at 09:54 PM Reply With Quote
There is a slight kink starting on the inner edge of the bend, not sure if you can see this in the pictures.
I think this could be down to the tube guide is not under the die centre line. It needs to have shoulders on the front face to allow it to sit below the die, so at present is 1&1/2 " behind the line, when I have done that I should be able to check for clearances and make sure the guide is as close to the die as possible.
Oval-ation is less then 90% so happy with that.
End bend 1
End bend 1
End bend 2
End bend 2
Adrian
[Edited on 12-1-13 by AdrianH]
posted on 13/1/13 at 12:02 AM Reply With Quote
I like that, more cunning than a very cunning thing. Top marks
I'd certainly be happy with that, all the effort has certainly paid off.
[Edited on 13/1/13 by MikeRJ]
clanger
posted on 13/1/13 at 09:15 AM Reply With Quote
decent bit of engineering, well done
AdrianH
posted on 13/1/13 at 09:44 PM Reply With Quote
The unit is now all but finished, changes to the guide height by lifting it up by 4mm kept the tube tight against the die on the inside bend. Decided to do a proper test bend on a new piece of tube so I marked out rings at 20mm spacing.
Final test bend 1
Final test bend 1
Stuck it in the rig with the first mark at the end of the half clamp
Final test bend 2
Final test bend 2
Took it out and stuck against a plate to take picture. No kinks at all nice and smooth so very pleased with the result.
Final test bend 3
Final test bend 3
Again checked the squash and got 41.25 mm so still happy with that.
Final test bend 4
Final test bend 4
Basic measurements are 70mm from first mark to start of bend and bend radius is 6.2 inches so I have 0.2 inch (5 mm) of spring when I take the tension off, the die is 6 inch radius.
I think I will clean and paint the unit before it goes rusty with the cold weather.
Now I need a tube notch-er!
Adrian
Theshed
posted on 22/1/13 at 09:58 AM Reply With Quote
You already have a tube notcher...... Use your milling machine in horizontal mode with a hole saw mounted on an arbour.
