Author: Subject: Racetech Mirror Thread??
posted on 14/5/11 at 06:46 PM Reply With Quote
Got some nice little racetechs for me cage.. DOH!
Mirror
Mirror
As soon as I took one out the box and saw the white nylock insert I knew....
I want to drill and tap the cage and mount these on the side.. anyone know what damn American thread they are??
Am I right in thinking its 1/4 UNF??
HOW TO CHECK???
snakebelly
posted on 14/5/11 at 06:57 PM Reply With Quote
not sure drilling holes in the cage is a good idea is it? maybe weldf a tab onto the cage the drill into that?
RichardK
posted on 14/5/11 at 07:04 PM Reply With Quote
Think he's welding in threaded inserts if I remember correctly.
Rich
Gallery updated 11/01/2011
lotusmadandy
posted on 14/5/11 at 07:06 PM Reply With Quote
I have a similar set on my cage.I drilled and tapped a hole.
It is m6 on mine mate.
amalyos
posted on 14/5/11 at 08:11 PM Reply With Quote
Use a large P clip, then you don't need to weld or drill your cage.
http://stevembuild.blogspot.com
posted on 14/5/11 at 09:56 PM Reply With Quote
WHAT THREAD IS IT!!!!!
indykid
posted on 14/5/11 at 10:12 PM Reply With Quote
SPA mirrors are 2BA, though that's more like m5
Not sure what yours are but don't discount BA. They may be 0BA if they're 6mm ish
HowardB
posted on 15/5/11 at 02:33 PM Reply With Quote
measure the diameter (OD) and then the threads per inch, that will allow you to look it up on the google thing,... otherwise the easiest way is to get some known threads and lay them side by side until you get one that meshes exactly with what you have.
hth
Howard
posted on 15/5/11 at 03:20 PM Reply With Quote
As Howard suggests measure the diameter of the threads and also the pitch then compare the measurements in a Zues chart (pitch gauges are pennies and will last a life time as will a Zues chart). HTH
