Author: Subject: Windscreen glass
matty h
posted on 27/5/11 at 06:42 PM Reply With Quote
Windscreen glass
What glass do I need for making a 7 windscreen car is already registered so no problem with IVA. Do I want toughened or laminated.
stuleah
posted on 27/5/11 at 06:48 PM Reply With Quote
I think i am correct in saying laminated. Touhened will shatter into lots of pieces and laminated willsmash but stay together. I am sure laminated is what is on std tin tops.
austin man
posted on 27/5/11 at 06:51 PM Reply With Quote
laminated, toughened will shatter and was the original screen glass until laminated screens took over
myke pocock
posted on 27/5/11 at 07:49 PM Reply With Quote
My windscreen man used a Land Rover flat screen to make mine. The advantage of this is that it has all the necessary markings on it that would be OK for IVA although I didnt need it as mine was SVA'd without a screen.
stevegough
posted on 27/5/11 at 08:09 PM Reply With Quote
If you just fit the side supports and the frame, you will save yourself ever having to clean the glass!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
skodaman
posted on 27/5/11 at 10:24 PM Reply With Quote
"If you just fit the side supports and the frame, you will save yourself ever having to clean the glass!" and you don't lose 10mph top end either.
Skodaman
stevegough
posted on 28/5/11 at 08:09 AM Reply With Quote
Luego Locost C20XE.
matty h
posted on 28/5/11 at 01:04 PM Reply With Quote
Thanks,do not need the markings so will probably just go to local glazing place and get a piece of laminated glas cut from a template.
whitestu
posted on 28/5/11 at 03:08 PM Reply With Quote
That's what I did to get a replacement for my Caterham screen - that was 4mm and cost about £35. I think some are 6mm.
Stu
[Edited on 28/5/11 by whitestu]
Mark Allanson
posted on 28/5/11 at 04:52 PM Reply With Quote
Autoglass, Mobile Windscreens cut laminated glass all the time for stuff like plant cabs, Tractors etc
