Author: Subject: Changing crown & pinion gear in diff
ChrisRidge
posted on 3/7/12 at 02:53 PM Reply With Quote
Can this be done in a pretty well equipped workshop or is it a specialist job? Does the end float & run out have to be set up?
Any advice welcomed!
Chris
daviep
posted on 3/7/12 at 03:00 PM Reply With Quote
Entirely possible but you will need to setup depth of mesh, pinion preload, crownwheel preload and backlash.
Davie
ChrisRidge
posted on 3/7/12 at 03:29 PM Reply With Quote
Thanks for that.
Might be better to buy a diff with the correct ratio already then.
jossey
posted on 3/7/12 at 07:35 PM Reply With Quote
But isn't it cheaper to change a 3.92 to something better than try buy a 3.14 etc????
David Johnson
