Author: Subject: Brake light switch thread?
fege
posted on 11/5/13 at 09:07 PM Reply With Quote
As the topic suggests, does anyone know what size thread the hydraulic brake light switch that's suppied has?
Se7en MNR R1 2012
http://www.youtube.com/channel/UCGX4w6Luh1A4tRKNuOBDWcg/videos?view=0&flow=grid
loggyboy
posted on 11/5/13 at 10:10 PM Reply With Quote
If its the same as most, its an imperial 3/8ths.
[Edited on 11-5-13 by loggyboy]
Mistral Motorsport
davidimurray
posted on 11/5/13 at 10:19 PM Reply With Quote
If it is metric will most likely be m10x1 tapered thread
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
fege
posted on 12/5/13 at 07:57 AM Reply With Quote
Thanks mates! I think my current switch is causing the spongy brake pedal and needs repacement. Or perhaps I should use an electical micro switch instead? Not sure yet..
Se7en MNR R1 2012
davidimurray
posted on 12/5/13 at 12:41 PM Reply With Quote
Is your switched mounted with the outlet at the bottom? If so it is possible to get air trapped. Try removing the switch and fitting a bleed nipple instead and bleed to see if you he a solid pedal. I added an extra tee on mine to get the switch on its side, with a bleed nipple on top.
fege
posted on 12/5/13 at 06:07 PM Reply With Quote
Yes, mine's mounted just like that. Thats the reason that I suspect the switch i causing my problems. I'll fit a bleed nipple and se what happens and take it from there. Thanks again!
Se7en MNR R1 2012
