Author: Subject: Fuel tank size problem
Kerr205
posted on 17/12/13 at 04:59 PM Reply With Quote
Ok. So ive gone and put another £13 in and it was full and started to drip out the right hand side of the twnk so ive either got a leak or an overflow and when putting in £34 before it was overflowing hugely and i never noticed!!!!!
How big are the fuel tanks on these usually??
renetom
posted on 17/12/13 at 05:44 PM Reply With Quote
Hi
That seems like a very small tank 9.6 ltrs ?
Ours is 6.5 gals aound 30 ltrs
also our filler cap is on top not on the side like most
which are a pig to fill & prone to leaks.
Good luck.
bill132hotrod
posted on 17/12/13 at 07:05 PM Reply With Quote
Fuel tank
Hi have you got a non return valve in your breather, I did not in the beginning and when I filled mine it overflowed via the breather and started to syphon the fuel out.
PERSEVERANCE is the word of the week. Stick with it the results are SWEET.
