Author: Subject: Front hubs
Gaz4562
posted on 1/6/14 at 07:54 PM Reply With Quote
Front hubs
Are cossie 2wd front hubs/uprights, the same as standard sierra ones. Apart from the ABS sensors ?
garyt
posted on 1/6/14 at 08:13 PM Reply With Quote
hi the mushroom insert / shock hole is bigger (as is the 4x4 hub) not sure of any other differences though
posted on 1/6/14 at 08:31 PM Reply With Quote
Lower ball joint is not a taper fitting on the Cosworth
Gaz4562
posted on 1/6/14 at 08:42 PM Reply With Quote
Yeah, just realised that when I've just tried them. Everything else seemed ok. Looks like I be swapping them then.
