Author: Subject: Can you guess what it is yet?
Avoneer
posted on 14/3/06 at 09:59 PM Reply With Quote
ecosse
posted on 14/3/06 at 10:05 PM Reply With Quote
rear wheel arch mould?
DIY Si
posted on 14/3/06 at 10:08 PM Reply With Quote
A really big minging green cheese wheel?
indykid
maybe a little further forward than a rear arch? bracketing will be a bugger though!
looks promising.
tom
DIY Si
Or a loo seat in the making for someone with a REALLY wide ass?
DorsetStrider
A sort of rabbit type thing?
Who the f**K tightened this up!
mookaloid
posted on 14/3/06 at 10:12 PM Reply With Quote
Spare wheel cover?
ProjectX
posted on 14/3/06 at 10:26 PM Reply With Quote
Jennifer Lopez's bog seat!
billy
CHEESE gromit
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
Humbug
posted on 14/3/06 at 10:27 PM Reply With Quote
Wheel for a blind hamster?
Avoneer
posted on 14/3/06 at 10:38 PM Reply With Quote
Any more ???
Anyway, it will be a 180 degrees front cycle wing buck with a very close fit on 13" wheels.
Nobody makes cycle wings to suit a 13" so I though I'd have a crack myself.
Watch this space as they say - will take a few weeks though!
Pat...
NigeEss
Cover for a flat tyre ?
Chippy
posted on 14/3/06 at 10:54 PM Reply With Quote
Would only make one comment Pat, don't make the same mistake that I did, and make the side skirts too deep. After fitting my guards I couldn't take the f*****g wheels of, Doh! ATB Ray.
k33ts
posted on 14/3/06 at 11:02 PM Reply With Quote
i couldnt get my wheels of easily so i welded a nut in the supports and thred locked bolts in so i could remove wing before wheel.
also enables you get wing closer to the wheel.
Avoneer
posted on 14/3/06 at 11:08 PM Reply With Quote
Cheers.
They were close on my Avon, but just right.
Approx 10mm air between arch and tyre.
Pat...
Guinness
posted on 15/3/06 at 07:35 AM Reply With Quote
Are you going to put vents in the top, or a little wing ala Caterham and the CSR? to help reduce pressure under them?
Or is the plan to get them so close you don't need them?
Mike
Triton
posted on 15/3/06 at 10:10 AM Reply With Quote
Good for you Pat..at last a cover for those daft 2 quid coins.
Sent you u2u by the way.
Mark
www.tritonraceseats.com
www.hairyhedgehog.com
posted on 15/3/06 at 11:06 AM Reply With Quote
It's a round of Edam with a puncture...
