Author: Subject: rear wing protectors...
posted on 7/8/06 at 07:03 AM Reply With Quote
job done; decided to pull off the carbon fibre plastic sheet, acid prime and paint in black (going for a black/red theme; yes, I should have painted the bonnet black too instead of hand polishing for weeks but ....),
I mean, stainless is so all very common
... and since I had the sheet already cut, then might as well use that in locost fashion
arch protectors
arch protectors
Alfa145
posted on 7/8/06 at 10:40 AM Reply With Quote
Looks good.
Whats the name for the type of edging strip you have round your bonnet intake cutout? I've looked around but can only find the larger herringbone type stuff.
posted on 8/8/06 at 11:02 AM Reply With Quote
Originally posted by Alfa145
Looks good.
stuff from maplins, locost too
I believe it has SVA happy radius but need to check.,..,,
