Author: Subject: Biggest possible radiator in a Vortx? 52x46cm?
ElmrPhD
posted on 9/12/15 at 10:05 PM Reply With Quote
My (now, former) supplier, whom I loath, supplied me with a 52cm tall x 46 cm wide rad'. I guess it's a "cross-flow" as the tanks are on the side and the tubes run horizontally. In order to fit it (if it will fit), I'll need to cut out nearly all of the lower vertical edge of the nose-cone and even several mm on each vertical edge. I don't mind that so much if I can squeeze it in, but I'd hate to cut up my nose-cone only to find that the top corners still won't clear.
Has anybody wedged in such a beast or have an idea of what's possible?
Thanks for any tips.
Steve, in the NLs
big-vee-twin
posted on 9/12/15 at 11:01 PM Reply With Quote
Mines mounted at an angle which directs the warm air off the back downwards to the road, I have used a SEAT Leon rad which is quite big.
http://www.triangleltd.com
sdh2903
posted on 10/12/15 at 05:50 PM Reply With Quote
Would it not be less hassle to go for something like this? And flog on the one you have. They also do a 55mm thick version if you don't need one 70mm thick.
VW POLO DERIVED WESTFIELD & OTHER KIT CAR, 70MM ALUMINIUM RACE RADIATOR UK MADE.
ian locostzx9rc2
posted on 10/12/15 at 06:01 PM Reply With Quote
I have fitted one of those to my striker excellent bit of kit and reduced my temps by 10 degs
sdh2903
posted on 10/12/15 at 06:04 PM Reply With Quote
Which did you go for? I'm about to order one for my mx5 vortx. I think the 55mm will be plenty?
ian locostzx9rc2
posted on 10/12/15 at 06:40 PM Reply With Quote
I got the 55mm one its one of the best purchases I have made dropped temps from marginal to 85 to 90 deg on track .
[Edited on 11/12/15 by ian locostzx9rc2]
[Edited on 12/12/15 by ian locostzx9rc2]
ElmrPhD
posted on 11/12/15 at 10:53 AM Reply With Quote
Thanks for the tip. Tried that with my cardboard template, but the (at least the unique MNR) nose does not care what angle this huge radiator is at - it just won't quite fit in there.
Thanks, again,
ElmrPhD
posted on 11/12/15 at 11:10 AM Reply With Quote
Of course, you are right and I may end up doing exactly that, especially since I took the effort to make a template which proved I must find an alternative.
Anybody want a really nice, unused 52cm tall x 46 mm wide ally race rad'???
The ebay radiator looks like what I'm after except that I wish it were a bit taller to better fit my big, new fan...
Thanks a bunch!!!
ElmrPhD
posted on 11/12/15 at 09:31 PM Reply With Quote
So, I went with a €28 (incl. tax) VW2038. Incredibly cheap, alloy core with plastic tanks, and I've read only good things about them.
To be honest, I don't understand why the need to produce an all-alloy race version, unless there have been a bunch of joint/bonding failures between the plastic and ally. But the chatter on these forums suggest they hold up well. Oh, one thing is that this is merely a 34mm deep core, whereas the "race" versions CAN be deeper. We'll see what happens.
Anyway, thanks again for your help.
Steve, in the NLs
Thanks a bunch!!!
