Author: Subject: rear lower wishbone rosejoints
Dillinger1977
posted on 6/8/05 at 04:33 PM Reply With Quote
hi chaps,
do the rear wishbone rosejoints normally need to be shortened?
mine dont quite screw in the entire length, and when its assembled with them protruding its got insane camber.
just checking before i carve up expensive things
-Rog
smart51
posted on 6/8/05 at 06:35 PM Reply With Quote
Mine has a lot of camber at the moment. I plan to set it up later in the build. I assumed that it could be done without the use of a hacksaw. I hope so at least!
Dillinger, you could try moving the tops out if the bottoms won't go in any further.
marc n
posted on 8/8/05 at 07:25 AM Reply With Quote
might need threads cleaning on the wishbone tubes, because they are unf the threads are very fine and the slightest bit of powdercoating or grit will sieze them up !!!!
best regards
marc
