Author: Subject: steering wheel; sva requirement
Flamez
posted on 23/11/08 at 08:40 AM Reply With Quote
I have a 300mm suede covered 3 spoke steering wheel.
Do SVA require a centre pad, if so what have others done to satisfy the requirement?
steeringwheel
steeringwheel
I will replace the hex bolts with domed type when I find some...
[Edited on 23-11-08 by Flamez]
my build mac1motorsports
speedyxjs
posted on 23/11/08 at 08:45 AM Reply With Quote
Is the centre padded?
Lars
posted on 23/11/08 at 10:24 AM Reply With Quote
My centre was not covered and passed ok. All he checked was edges.
Lars
lsdweb
posted on 23/11/08 at 10:28 AM Reply With Quote
Phil
I'll bring some dome head bits in tomorrow - they're either 6 or 8mm at a guess.
Wyn
Ben_Copeland
posted on 23/11/08 at 10:58 AM Reply With Quote
I thought it was an SVA requirement that it was padded
Lars
Ben
Locost Map on Google Maps
Enter Your Details Here
Lars
posted on 23/11/08 at 11:29 AM Reply With Quote
Not sure if its a requirement, but he took his dome shape to it to look at edges, so he definitely had a close look at it.
Lars
StevieB
posted on 23/11/08 at 12:32 PM Reply With Quote
Make a pad out of inch thick dense foam and stick it to the centre of the wheel. At least that way you'll not fal foul of the SVA man either way.
I also think that if you present a car that exceeds SVA standards and looks like you've made some effort and put a bit of thought into it, there may be a bit of leniency when the testers own judgement and interpretation is required for some parts of the test.
grusks2
posted on 23/11/08 at 07:18 PM Reply With Quote
mark & colin have a SVA friendly wheel that you can borrow ive been told.
http://mac1worxbuild.wordpress.com/
forgot my old password so another username doh
DarrenW
posted on 24/11/08 at 09:41 AM Reply With Quote
I used aftermarket wheel. Centre wasnt padded. Used dome headed bolts and ensured the spokes had correct spec rads (SVA man did check them). Also had to use collapsable boss.
The reason most use OE wheel is that they are type approved. Hence having to use collapsable boss with aftermarket wheel.
Only 3 bolts - does this suggest you have it fastened to a QR boss? Some places dont like them (Gosforth said no when i asked 3 years ago).
bigrich
posted on 24/11/08 at 11:50 AM Reply With Quote
They most certainly do
jos
posted on 24/11/08 at 06:45 PM Reply With Quote
you might like to consider using the standard sierra wheel purely for sva as the bigger the steering wheel the bigger the exempt zone
[Edited on 24/11/08 by jos]
