Author: Subject: Toothed wheel trigger point
posted on 27/11/06 at 11:30 AM Reply With Quote
I'm in the process of fitting my toothed wheel, but there's one thing I'm not sure about - which bit of the wheel should be 90 degrees BTDC?
In the attached picture below, "A" is the dead centre of the missing tooth, "B" is where the leading edge of that tooth would have been, and "C" is the leading edge of the next tooth.
Which point should I aim the VR sensor at when the engine is at 90 degrees BTDC? (I think it's "A", but it's nice to get it right from the very start).
cheers,
scottc
posted on 27/11/06 at 11:53 AM Reply With Quote
I would guess at point 'A' as that is where the tooth is missing from.
But its only a guess so another useless comment from me
whitestu
posted on 27/11/06 at 12:06 PM Reply With Quote
This might help [from MS website]
[Edited on 27/11/06 by whitestu]
paulf
posted on 27/11/06 at 12:40 PM Reply With Quote
Point A , the centre of the missing tooth is correct.
Paul
posted on 27/11/06 at 12:41 PM Reply With Quote
Excellent! Point "A" it is then (presuming that MS works the same as MJ - no reason why it shouldn't)
I panicked a bit when I saw "5 teeth ahead of sensor" but then I saw "EDIS-8" - phew!
paulf
posted on 27/11/06 at 12:45 PM Reply With Quote
Set it 9 teeth past the sensor when the engine is at tdc, if the sensor is at 9 0clock the gap will be at 12 oclock when the engine is on tdc. I had to think about it when I did mine , it is a simple concept but seems to confuse many people and the more you think the more confusing it becomes.
Paul.
posted on 27/11/06 at 01:36 PM Reply With Quote
Does the nine teeth include the one that should be where the gap is? If the sensor is at 0900 and the gap is at 1200 then the gap is 270* before TDC isn't it? Sorry if I'm being obtuse but I'm trying to get my head round this as I've got a 1.8 zetec sitting in the shed which I am fitting eventually
paulf
posted on 27/11/06 at 02:40 PM Reply With Quote
Dont fully understand how you mean, but if fitting a zetec then you dont need to worry as the flywheel has the trigger point built in , unless you intend using a CVH flywheel in which case you will need to fit a trigger wheel.
Paul.
posted on 27/11/06 at 03:22 PM Reply With Quote
I cheated - after painting my pulley I made a mark with correcting fluid exactly 90 degrees prior to the TDC mark. If I put that on the block's timing mark then the missed tooth should be right under the sensor.
I hope that's correct!
Rob Lane
posted on 27/11/06 at 05:24 PM Reply With Quote
David,
It's worth downloading the msns extra manual in pdf. There's full details of the tooth setup in it along with diagrams.
The 9 tooth setting is correct.
Tried to upload it to photos area but can't. So it's on my site here :-
MSnSEXtra Manual
Rob
[Edited on 27/11/06 by Rob Lane]
Rob Lane
posted on 27/11/06 at 05:41 PM Reply With Quote
Forget that, it's now out of date.
See here for better description.
MSnsExtra Manual
posted on 27/11/06 at 06:28 PM Reply With Quote
Thanks to everyone for your info - I've been making up the bits & pieces required for the VR sensor and, at the moment, it seems to be coming together well. Once Namrick supplies the slightly-longer bolts I require then I'll know whether my design works!
Fixing this sensor is the hardest part - everything else is wiring & brackets (he says, radiating over-confidence). I can work towards fitting the rest of it while still playing with the car, until it's "cut-over time".
One question - my VR sensor's cable is too short - any ideas on how to extend it without compromising the screening? (I'll get the cable from the bloke who sold me the trigger wheel).
cheers,
BTW: Looking at that MS manual made me realise that I'm just not ready for that yet!
[Edited on 27/11/06 by David Jenkins]
paulf
posted on 29/11/06 at 10:15 PM Reply With Quote
It is possible to get the plug with pins and a rubber boot from Premier and some other wiring suppliers. I extended mine using RS232 network cable and just soldered and heatshrinked it originally.
I have since managed to remove them from Fiestas in the scrapyard with enough cable attached to allow installation without extending them .Fiestas are good as many have the senor wire running around the front of the engine and along the front crossmember to the edis on the wing.It is easy to get at and not to tied into the other loom as on some of the other cars.
The plug is a junior power timer type.
Paul.
Agriv8
posted on 5/12/06 at 09:41 AM Reply With Quote
going on a scrap yard raiding session this aternoon for the trigger sensor ( the trigger wheel is alraedy bolted to my crank pully - done on the last engine swap ). looks like a fiesta is the favorite due to the length of the connecting wire.
To save me getting to wet trough seracing what fiesta and approx age are likley candidates for me ripping the required bit off.
Ps dont need edis unit as my coils are driven directly from my VEMS unit
many thanks
Agriv8
paulf
posted on 5/12/06 at 03:26 PM Reply With Quote
Any early 90s fiesta with the valencia engine will have one , it is mounted at the front of the engine with a single torx screw.
Paul.
many thanks
Agriv8
Agriv8
posted on 5/12/06 at 08:41 PM Reply With Quote
thanks paul.
didnt get away today bloomin computers at work playing up
Valencia engine not com across them ( moved onto VW's as I grew out of fords litterally )
thanks Again
Agriv8
