Author: Subject: indicators just stopped working
Jasper
posted on 26/8/03 at 02:13 PM Reply With Quote
My indicators and hazards have completely stopped for no apparent reason. They are not on and not flashing, they don't come on at all.
It still amazes me that I actually wired them up, and I'm not sure where to start looking for a problem. The only obvious thing I can think of is an earth problem.
Any other thoughts - BTW fuses are all ok and everything else works fine.
ned
posted on 26/8/03 at 02:20 PM Reply With Quote
flasher unit/relay??
Ned.
beware, I've got yellow skin
Jasper
posted on 26/8/03 at 03:31 PM Reply With Quote
Wouldn't they just stick in the on position then? God I hate electrics!
I do get an occasional very intermittent flash out of them.
theconrodkid
posted on 26/8/03 at 04:45 PM Reply With Quote
give the flasher unit a smack or remove cover and twiddle contacts
who cares who wins
pass the pork pies
eddie
posted on 26/8/03 at 05:35 PM Reply With Quote
This may sound daft, but it could be your hazard warning switch.
Try turning your hazards on, if they work, then its probably your hazard switch.
PLEASE NOTE those black rectangular rockers sold to kit builders (see 2 posts below), are of really poor quality. Being a vehicle electrician, i have found that the number of those things i've changed, make me wary of fitting them to anything
[Edited on 26/8/03 by eddie]
Please feel free in advance to: correct, update, ridicule or laugh and point at any comments made by myself in this post....
darren(SA)
posted on 26/8/03 at 09:02 PM Reply With Quote
I suppose it depends on which flasher unit you have,
I tried to use a damaged one the other day and I got no response, whatsoever.
cheers
darren
eddie
posted on 26/8/03 at 10:09 PM Reply With Quote
pic didnt come out, try again: Rescued attachment rsswitch.jpg
ChrisW
posted on 27/8/03 at 08:14 AM Reply With Quote
Jasper
Flasher unit could stick in either position so that would be my first port of call.
Connected to the flasher unit you should have switched live, earth, and the connection to the indicators themselves. Try connecting the switched live straight to the indicators wire and see if you get fixed (non flashing operation). If so it's most probably the flasher unit.
Chris
My gaff my rules
stephen_gusterson
posted on 27/8/03 at 09:53 AM Reply With Quote
as Jasper doesnt seem confident in electrics, id lay money on a bad connection. If you have used crimps, are they done properly?
any fuses in line?
atb
steve
Jasper
posted on 27/8/03 at 10:42 AM Reply With Quote
Are you casting nasturtions on my wiring abilities!!
All butt connections are soldered, terminal ones are crimped - but with the decent ratchet crimper.
Just bought a new and apparently better quality flasher unit (metal bodied) from my local factors - will try it tonight.
My hazard switch is a decent round hella one, so don't think it's that.
Cheers for the feeback.
Just 9 more posts to the big 1000!!!
[Edited on 27/8/03 by Jasper]
stephen_gusterson
posted on 27/8/03 at 12:24 PM Reply With Quote
course I wasnt!
you just didnt put out positive vibes, so i thought id go for the simple ideas first!
You need a multimeter, and chase thro the wiring to see where you lose the volts. Changing the flasher is a good idea, but there are more connections than flashers......higher probability.
If only my car was just minus indicators
atb
steve
Jasper
posted on 27/8/03 at 02:11 PM Reply With Quote
Got a mutlimeter - shame I don't know how to use it! - Only joking, I can use the basic functions.....just
posted on 27/8/03 at 06:19 PM Reply With Quote
You only need the continuity bit anyway Jasper. If it beeps it's o.k.
yours, Pete.
eddie
posted on 28/8/03 at 01:50 AM Reply With Quote
MULTIMETER???
dont hold with this new fangled madness,
give me a test lamp any day.....
