Author: Subject: VR Sensor Pinto bracket
karlak
posted on 22/6/10 at 10:12 PM Reply With Quote
Does anyone have a bracket that they may have used on a Pinto for a VR sensor. I know there are several sites showing homemade ones, but I am bloomin useless at making things like that.
It is the last bit I need to get my Megajolt up and running.
Cheers in advance and hope
[Edited on 22/6/10 by karlak]
MK Indy - 2litre Duratec - Omex 600 - Jenvey throttle bodies - ETB DigiDash2
blakep82
posted on 23/6/10 at 07:01 AM Reply With Quote
not cheap, but anything from here any use?
http://trigger-wheels.com/store/contents/en-uk/d11.html
________________________
karlak
posted on 23/6/10 at 07:16 AM Reply With Quote
Thanks for the pointer... I think the issue there is that none of them are a direct fit. So I would end up bending, banging , grinding and swearing to get it to fit. Oh, and have cost me loads of money for the pleasure
Was hoping more for a direct bolt on to the pinto. Not sure that one exists, which is quite surprising, as if someone were to make up a batch I am sure money could be made ?
Anyway, if anyone does have anything they have used in the past and is now surplus to requirements please let me know.
RichardK
posted on 23/6/10 at 09:22 AM Reply With Quote
If you get stuck I should be able to knock you one up, but you'd have to tell me the dia of your trigger wheel, I've got pictures in my gallery (link on the banner below) but you'd have to drill the mounting holes.
Rich
Gallery updated 11/01/2011
RichardK
posted on 23/6/10 at 08:31 PM Reply With Quote
Didn't have anything to do tonight so here you are..
Your Megajolt Sensor Bracket
Hopefully you'll be able to weld them where they meet, have left a bit extra on at the ends so you may have the cut them shorter.
Cheers Rich
RichardK
Looks better than the original version
My Megajolt Sensor Bracket
[Edited on 23/6/10 by RichardK]
karlak
posted on 27/6/10 at 06:35 PM Reply With Quote
Thanks Rich,
it has arrived safely. Many thanks for your help and hopefully will get it all fitted this week.
You are a true Gent and a Saint
